Think I should use the stock pushrods?
Old Oct 25, 2007 | 07:59 AM
dawg's Avatar
dawg
Default Think I should use the stock pushrods?
With the 08, popping the fuel tank is easy and you don't have to drain. The rocker box gaskets are a heck of a lot cheaper than $112 it will cost for adjustables. I intend to pop the cams in this winter and then save up for the 103 for next winter. What do ya'll think about just re-using the stock pushrods and saving some coin? There's no need to remove the pushrod covers is there?
Old Oct 25, 2007 | 08:03 AM
bigdoghd's Avatar
bigdoghd
Default RE: Think I should use the stock pushrods?
If you don't mind doing the extra work than by all means do it that way. I always replace them with time savers and just cut the old ones. It's really just a time thing and last chance of damage taking anything else a part.
Old Oct 25, 2007 | 08:04 AM
js124's Avatar
js124
I would use the adjustable pushrods . If you go into the motor more than twice labor alone will pay for them .
Old Oct 25, 2007 | 08:18 AM
harris48cars's Avatar
harris48cars
I reused the stock one when I did the BB & cams. I no most people are programmed to use adjustables (I know I was) but my mechanic said 'Why waste the money, there's nothing wrong with the stock ones'. Made sense to me. Now if you're milling heads, using a much thinner head gasket, etc.. then that's a different story.
Gary
Old Oct 25, 2007 | 09:36 AM
Harleypingman's Avatar
Harleypingman
When I installed HQ 0034 cams (.500 lift) I asked Doug if I could reuse the stock pushrods; he approved.
Old Oct 25, 2007 | 09:42 AM
sugarbear's Avatar
sugarbear
Unless you are going radical with the cam use stock. With the adjustables you have one more thing to adjust or go wrong and are adding weight to the valve train to have to move.
Old Oct 25, 2007 | 10:08 AM
Uncle Peepers's Avatar
Uncle Peepers
I agree; use the stock ones so long as they're okay with whatever cams you're installing. I'm doing some headwork on my bike this winter. When I put it back together I plan to re-use the stockers rather than re-installed the adjustables. If the top's coming off, it's a lot easier to drop in the stock ones than to screw around adjusting the adjustables---and you'll never wonder if you got them right (I'm a little obsessive this way).
Uncle Peepers
Old Oct 25, 2007 | 10:19 AM
rtb's Avatar
rtb
Especially being easier on an 08, definitely re-use the stock pushrods. You hear tell of easy installs loosing up, plus the stock ones don't need to be adjusted. BTW...be sure to mark them and put them back where they came from. The stock pushrods are not all the same lenght.
Old Oct 25, 2007 | 10:55 AM
Big Peter's Avatar
Big Peter
ORIGINAL: dawg
I used the stock pushrods after installing
S&S .510G gear drive cams.
www.sscycle.com/modules/instruction/uploads/51-1047.pdf
With 510G cams stock pushrods are OK, with higher lift
cams you have to use adjustable rods.
Greetz,
Peter
Old Oct 25, 2007 | 11:28 AM
olgreydog7's Avatar
olgreydog7
ORIGINAL: Harleypingman
That's all I needed to hear
