Pinging
Old Nov 5, 2007 | 07:05 PM
cardboard's Avatar
cardboard
Default RE: Pinging
The TM will take care of everything at all Rpm's. It will read the oxygen sensors and the TPI sensor to adjust the timing and fuel for you. You can order the TM with the present setup on yer bike so all you have to do is install it, the wide band oxygen sensors and initalize it. If you make future changes you can change the base map.
Old Nov 5, 2007 | 07:13 PM
stro1965's Avatar
stro1965
Default RE: Pinging
ORIGINAL: cardboard
FYI- Auto tune doesn't adjust timing as far as I know. AFR's only.
Old Nov 5, 2007 | 07:18 PM
captjon37's Avatar
captjon37
Default RE: Pinging
Any tuner will work wonders. Just shop around and do some reading to see what fits your ideas and budget. You have a few choices with an 07. Forget the download. TUNER is the shiznit.
Old Nov 5, 2007 | 07:52 PM
cardboard's Avatar
cardboard
Default RE: Pinging
ORIGINAL: stro1965
ORIGINAL: cardboard
The Tm Auto Tune wil not change yer timing maps.
You have to change the timing maps manually in the program. YOu have to be careful changing the timing maps, and do it in very small incrementsor you can burn yer engine up. If the bike is running lean all you need to do is add more fuel.
My builder has changed the timing on bikes with the TM. I think he does it on the dyno when changing the timing.
Old Nov 5, 2007 | 10:52 PM
atexn4christ's Avatar
atexn4christ
Default RE: Pinging
I had the problem when I was using Arco gas switched to Chevron no pinging. It was a whole three cents cheaper.
Old Nov 6, 2007 | 02:26 AM
stu07hd's Avatar
stu07hd
Default RE: Pinging
My solution was this. I know that the HD Stage 1 download isnt always the most popular with persons on the board, but it works well for me.
I have had the HD Stage 1 downloaddone to my Ultra. It solved my spark knock issue and the bike seems to run a bit cooler. I had it done at the same time I put Rush 2.0 Slip-ons on. If you plan to change air cleaners or switch pipes frequently you may consider a fuel programmer. It may be cheaper in the long run. I paid $150 for the stage 1 remap at my dealer. Was it money well spent, probably so since the spark knock is gone. I know that it is HD's issue, but I coulnd't sit there and listen to my way to expensive toy destroy itself internally.
D W K
Nov 28, 2015 11:47 PM
prezflyr
Feb 22, 2014 07:31 PM
MGN54
Oct 26, 2010 10:22 PM
95ci springer
May 24, 2009 10:37 AM
118811fh
Oct 12, 2008 05:08 PM
