RKC passenger backrest
Old Nov 9, 2007 | 01:46 PM
Romee08RKC's Avatar
Romee08RKC
Default RKC passenger backrest
Does anyone know if there is a difference between the passenger backrests between the FLHR and the FLHRC? Specifically, I want to know if HD part # 96355-08 which is the riders essential kit for the flhr will fit the flhrc?
Old Nov 9, 2007 | 01:54 PM
gunrunner's Avatar
gunrunner
Default RE: RKC passenger backrest
Fit is the same, just different pattern on the seat and backrest.
Old Nov 9, 2007 | 01:58 PM
I am Jerry's Avatar
I am Jerry
That looks to be the same parts I bought separately for my RK Classic with the exception of the skull thing. Should work
Old Nov 9, 2007 | 02:06 PM
Romee08RKC's Avatar
Romee08RKC
I have a chance at a good deal on this. Eventually I will be adding the tour pak. If this fits, this will really help on the funds expended. Every little bit helps.
Old Nov 9, 2007 | 02:18 PM
I am Jerry's Avatar
I am Jerry
Good luck with it. You know the only thing from this setupthat will work with the removable tour pak is the froward dock points don't you?
Old Nov 9, 2007 | 03:03 PM
Romee08RKC's Avatar
Romee08RKC
One of the reasons that I am asking. Now when you say only the forward docking points, what passenger backrest would you use if you had the tour-pak off?
I was hoping that once I purchased the tour pak, that when it was not on the machine, I could put the backrest on and hook up to the same docking points?
Old Nov 9, 2007 | 06:45 PM
I am Jerry's Avatar
I am Jerry
You're almost right Romee, the regular backrest uses two points on each side. The removable tour pak uses the forward mounts but has separate mounts that are farther back than the rear ones on the backrest. By adding the mounts for the tour pak you can swap back and forth between the two.
Old Nov 9, 2007 | 06:48 PM
I am Jerry's Avatar
I am Jerry
BTW, I picking up my rear mounts tomorrow. I'll try and take some pics of the install.
Old Nov 10, 2007 | 06:48 PM
I am Jerry's Avatar
I am Jerry
Here you go Romee, this is the forward dock points for the regular backrest.
Here is the rear docking points used for the tour pack.
Old Nov 10, 2007 | 06:52 PM
Blackmouth's Avatar
Blackmouth
Romee...if you don't already have the docking kit installed on your scoot:
do a search here on the forum regarding that docking kit.
The instructions that come with it are useless.
The info given on this forum will help you 10 times greater than those damned instructs.
Peace.
