BUB 7 install 07 Ultra and a wee little problem
Old Nov 17, 2007 | 01:33 PM
Hogbroke's Avatar
Hogbroke
Default BUB 7 install 07 Ultra and a wee little problem
In attempting to remove OEM starter bracket toinstall the new one. I dropped, not one but two small torx bits downthe cavity right in front ofthe starter. They dropped down there somewhere. The starter is not removed and I have managed to get one out by spraying water down behind it. The other one has disappeared into the bermuda triangle. Can't see down in there, but appears to be the belt drive sprocket right below. The bike rolls fine and all attempts with water and air to dislodge it have been futile. The question is should I ignore it and let it vibrate out on its own or what. Any suggestions you have will be greatly appreciated.
Old Nov 17, 2007 | 01:54 PM
electaRICK's Avatar
electaRICK
Default RE: BUB 7 install 07 Ultra and a wee little problem
did ya try a magnet
Old Nov 17, 2007 | 02:55 PM
Hogbroke's Avatar
Hogbroke
Yes I did, also wire and everthing that would fit down the crack.
Pitbull_Dallas
May 27, 2019 01:05 PM
mps1168
Aug 5, 2010 07:17 PM
mps1168
Aug 5, 2010 05:33 PM
amigos4
Jul 18, 2007 10:02 PM
amigos4
Jul 18, 2007 09:12 PM
