Cold weather start after sitting
Old Nov 22, 2007 | 10:11 PM
creep1's Avatar
creep1
Default Cold weather start after sitting
My o7 RG has been sitting for a couple of weeks. its cold here in ny. Went to start it yesterday and it stalled a bunch of times before kicking over and idleing smooth. Now im thinking fuel injection shouldnt act this way but then again I have a tmax that ive been struggling with. The last adjustment was the iac. Was running and starting up great until now ( the sitting around). Anyone else experiencing anything like this or any suggestions would be great.
Old Nov 22, 2007 | 10:20 PM
beemer737's Avatar
beemer737
Default RE: Cold weather start after sitting
It shouldn't act that way.
Maybe bad gas, do you use a fuel dryer additive, the stuff from HD works pretty good? When it sits is the tank full, helps prevent condensation.
Old Nov 22, 2007 | 10:28 PM
creep1's Avatar
creep1
so your thinkin its a fuel issue??? That would be the best case scenario for me. That tmax unit is wearing me out.
Old Nov 22, 2007 | 10:39 PM
cowboyglide's Avatar
cowboyglide
You may already be doing this but if not make sure you wait until the fuel pump quits running when you turn the ignition on before you hit the start switch. This pressureizes the system and is even more important when it hasn't been started in a while. If it stalls turn the ignition off and then back on and wait for the fuel pump to stop again before hitting the start button again.
Turning the ignition off resets the tmax to the cold start mode. This may notsolveyour problem butto me it sounds like your tmax just didn't set itself in the cold start mode when you started it the first time.
Old Nov 22, 2007 | 10:55 PM
creep1's Avatar
creep1
That makes sense. Gonna be conscience about that next time. Thanks
Old Nov 22, 2007 | 11:23 PM
hep0950's Avatar
hep0950
I agree with cowboyglide. Sitting for just two weeks shouldn't bother it.
Old Nov 23, 2007 | 09:01 AM
mllkn6's Avatar
mllkn6
How long have you had the Tmax up and running, might not have had the time to fully adjust itself out. Just guessing, I agree with cowboyglide also, I don't have my Tmax yet, hope it comes in today if I'm lucky, but I've been reading up on them trying to get a head start on working with it. Like the above member said, it shouldn't be hard to start with only two weeks of sitting, I rode mine yesterday after 2 weeks of setting in my shop without a battery tender on it and it started the first time. What kind of problems are you having with it?
Old Nov 23, 2007 | 09:04 AM
mllkn6's Avatar
mllkn6
What kind of problems are you having with the Tmas? Should have been more specific in my reply. I didn't proof read it, sorry.
Old Nov 23, 2007 | 09:53 AM
cdale976's Avatar
cdale976
I ride all year here in Pa in fact was out this morning 27 degrees.
07 rkc with sert and air and pipes. spits a bit but comes around quickly. for certain you need to let pump pressure up and run good gas especially if sittin a few days here and there. whent hw white stuff hits i generally add stabil to full tank. gas is different in winter....
sounds like you need to get the tmas squared away. not familiar with them but hear good stuff....
Old Nov 23, 2007 | 10:04 AM
creep1's Avatar
creep1
Im almost thinkin the tmax is actin up. Should I have the computer checked to see if any codes come up ??
