"DIY MODS" and TRICKS to SAVE $$$$$$
Old Jan 19, 2009 | 02:11 PM
  #351
moondog99's Avatar
moondog99
I was thinking of sending a solo seat I have to someone to get it reformed and then it hit me that I have an old seat in the workshop. I got the old seat removed the seat cover and with a 4" grinder with a standard grinding disk and a variable speed sander I reformed the old seat. Then I put the seat cover back on, being sure I pulled it tight, using an electric stapler. Turned out great. So then I removed the solo seat from my EGC and did the same to that seat. And less than an hour later I was done. It looks great and much more importantly it feels great. I shaved down the sides enough to now I can be flat footed at stop lights. It was so easy to do, find a old seat and give it a shot!
Old Jan 21, 2009 | 06:34 PM
  #352
gmc's Avatar
gmc
Chrome French Headlight Ring Gap on ELectra Glides. If the new ring hits the fairing and leaves a gap, the light has to be move out with something behind it to get some depth. I just got the French ring #69627-99 yesterday and had about 1/4 " gap on the right side but the ring edge was all the way back to the fairing. Went to the shop today and the service manager says some just fit that way and there were two there that had the gap. I loosened the inner headlight retaining ring that holds everything in, put some rubber behind it, I had an old mouse pad that I cut in 1/4 " strips, you don't want any hanging out past the ring. Then you should check that you have the headlight out far enough, else put a little more packing behind the retainging ring and if OK realign your light . I also put a piece of rubber strip behind the OEM chrome ring where the little screw goes so that ring doesn't go so far back on the light. Then put your new chrome ring bezel on and you should have no gap! I think I'll replace the rubber strips w rubber washers behind the retaining ring.
__________________
Old Jan 25, 2009 | 03:33 PM
  #353
bigheadted's Avatar
bigheadted
Read in Hotbike ?? on free laydown plate mod for baggers. Just remove and redrill holes and free laydown plate. I did it and it was easy, looks good and was free.
Old Jan 25, 2009 | 06:16 PM
  #354
JaronB's Avatar
JaronB
license plate mounting hole cover now completed. No more plastic caps!!
COST:
Spikes $15 delivered off of Ebay.
Bar & shield license plate bolt FREE from my parts guy at Harley!!
Old Jan 28, 2009 | 08:05 AM
  #355
texaswiz's Avatar
texaswiz
Default Rusty ends on stock 2009 touring mufflers..the fix
Look at nearly any new 2009 touring bike and the ends of the mufflers will be rusted, even on the showroom floor. There is an easy and cheap fix for this. For less than $5.00 you can get a brass wire "fine" cup brush at the hardware store. Put it in your 1/4" electric drill and go to work. The small cup brush will remove any rust or crud in there and you will be left with a brilliant and shiny new tip on the "inside" end of your stock mufflers. You can either tape them off and paint black using a rattle can or simple buff them out once a month to keep that chrome look. The mechanic at the Harley shop happened to see mine in the parking lot and asked what I did. It told him. He said that if I didn't use official Harley paint that I would probably void my warranty. Then he laughed and said "Just kidding".
Old Jan 28, 2009 | 08:17 PM
  #356
YoDA's Avatar
YoDA
Originally Posted by berettag
In the spirit of "Improvosational Engineering" (I prefer that over jury rigging) I was removing myfairing from my Ultra yesterday and was being real carefull not to rub up against my spot lights and scratch anything, when it hit me. I reached into my rag bag (I keep for waxing and polishing) and pulled out two sweat socks, covered thespot lights and slid the fairing off, no fuss, no muss, no scratches.
Put a Harley Bar and Sheild on the socks, and they'd be Genuine Harley Davidson Scratch Inhibitors, $39.95.
Great idea! I'll try the socks!!
Old Jan 31, 2009 | 05:18 PM
  #357
Dave54's Avatar
Dave54
More of a trick than a mod Picked up a cheap 12 volt air pump and took it
out of the plastic housing to make it as small as possible ( takes up less room
in the saddle bag) then made up a plug to use ether in the cig lighter or plug
into charger plug on the battery carry tire plug kit with it just to get where
you can replace tire or air up my buddy,s front tire that has a slow leak !
Old Feb 1, 2009 | 08:48 PM
  #358
larry69fatboy's Avatar
larry69fatboy
Originally Posted by 007 ultra
Needed a light in the tour pac but didn't want to spend the bucks HD wants for their setup.
Went to AutoZone, purchased a glovebox light with intregrated switch for about $3.00. Mounted the light with doubleface tape to the lid of the tour pac near the lock. Ran wire down into the tour pac and taped in place with black Gorilla tape - then to a hot lead and a ground.
Open the lid, flip the switch and there is adequate light to see whatever is needed in the tour pac.
This job didn't take very long and did not cost much other than the purchase of the light with an intregrated switch.
Happy riding.
That's cool... Can you post a picturer of that?
Old Feb 4, 2009 | 12:03 AM
  #359
Jukebox's Avatar
Jukebox
Default Relocation or the Tour Pack
Has anyone tried to relocate a detachable tour pack by re-drilling holes in the bottom yourself ? I would like some info on this PLEASE ?
Old Feb 4, 2009 | 10:40 PM
  #360
XKROME's Avatar
XKROME
I'm not really into bling, don't like shinny stuff, (obvious by user name) and kinda like the vintage look. wanted to do something with the shift linkage but not pay the $$ for a cool replacement. got a lace maker from Tandy Leather, cut really long laces out of some old chaps and wrapped a double layer around the stock linkage while I had it off for some other repairs.
did the same on the Dyna along with the grips, clutch cable, front brake line and the forks between the triple tree's.
lace maker tool
