"DIY MODS" and TRICKS to SAVE $$$$$$
Old Feb 23, 2011 | 05:33 PM
  #781
utlonghorns416's Avatar
utlonghorns416
Originally Posted by mrnone
yep I am in.
loox great I want mine in royal purple
email me none@werule.com
email sent
Old Feb 27, 2011 | 09:33 PM
  #782
DaSarge's Avatar
DaSarge
Default LED Calculator
For those of you who are or wanting to experiment with LED arrays, I've used this calculator before when I created my own LED taillight on my previous chopper.
http://led.linear1.org/led.wiz
There are even companies out there that will make a couple printed circuit boards complete with drilled holes and solder traces already ran for fairly inexpensive.
I have to look at my schematics to see how I did it but there is a way to make standard LEDs dual intensity so they were being used as both running & brake lights. I'm not positive but I think what I did was take the incoming voltage (13V) and divide it in half and use that number in the calculator. All I know is when I got done with it I couldn't even look at it when full power was applied it was so bright.
Old Feb 28, 2011 | 06:30 PM
  #783
CheezyRiderAZ's Avatar
CheezyRiderAZ
DaSarge,
Any chance you're in AZ and wanna exchange a few beers for some LED help?
Old Feb 28, 2011 | 08:27 PM
  #784
Streets_Glide's Avatar
Streets_Glide
Stage II
I definately want to hear how much for a set, I have the same Crimson Sunglo bike.
Old Mar 1, 2011 | 07:34 PM
  #785
utlonghorns416
$225- bags and lids
$185 bottoms
You will have to glue them in. I will make them a little bigger and you trim to fit. I had to trim mine a bit to get the fit I wanted.
Im in Cincinnati OH.
Old Mar 4, 2011 | 11:41 AM
  #786
Jon 2005 Road King's Avatar
Jon 2005 Road King
Ok, here's my small mod. I just installed stretched hard bags and was terrified of loosing them or getting them stolen. So, I did the u-nut mod mentioned earlier in this thread, but used security Allen boles instead of just straight Allen bolts.
After I did that, I noticed that any Joe could still just reach in with a wrench and spin off the bolts holding the saddlebag bracket with the u-nuts, (even when the bags are locked closed) so I replaced those bolts with security Allen bolts too.
About 6 bucks for added piece of mind. What are the odds a thief will have security Allen wrench heads?
Old Mar 5, 2011 | 01:32 PM
  #787
Uncle Larry's Avatar
Uncle Larry
Originally Posted by hodgeaaco
Here are before and after pics of my brake pedal mod. I did not have enough room on the floorboard with the "giant" pedal HD puts on our baggers, so I cut down the pedal with a dremmel and put on a dyna pedal. Took about 30 minutes. Just be patient with the dremmel!!
That's a great idea! and here I was thinkin' I was gonna have to get smaller feet!
Old Mar 6, 2011 | 07:04 PM
  #788
SCFLHX's Avatar
SCFLHX
Default Change out your brake fluid
For all the do it yourself people here is a quick brake bleeding device a friend made and used until he passed in a motorcycle accident. This consists of an old spaghetti jar, 1/4" plastic tubing, a scrap of PVC sink drain, a scrap of wood to make a plug, a 3" strip of duct tape and his miti-vac. Just keep a snug fit from the holes to the tubing for good suction. After being asked how it works, he simply stated "It sucks". It works well and does not drain the reservoir too fast due to the small tubing. Just watch for the fluid to go clear as it enters the jar.
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-brake-bleeding-1.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-brake-bleeding-2.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-brake-bleeding-3.jpg
Old Mar 7, 2011 | 09:59 AM
  #789
ShatteredSoul's Avatar
ShatteredSoul
That's the same basic way I used to siphon gas out of cars for my dirt bikes when I was a kid!
Old Mar 7, 2011 | 05:43 PM
  #790
SCFLHX's Avatar
SCFLHX
If it works, don't fix it.
