"DIY MODS" and TRICKS to SAVE $$$$$$
Old Mar 8, 2011 | 10:10 AM
  #791
mechmatt's Avatar
mechmatt
I ordered 2 of these and they just came in and are pretty nice. I'm going to mount them in the saddlebags for tool storage. For about 20 bucks shipped I'll give them a try
http://www.amazon.com/Goodhope-Bags-Handyman-Tool-Belt/dp/B003VKXQVQ
Old Mar 10, 2011 | 03:27 PM
  #792
1BADASSCOP's Avatar
1BADASSCOP
them are some sweet, cheap MODS!! Good work everyone
Old Mar 14, 2011 | 11:35 AM
  #793
beammeup's Avatar
beammeup
subscribing to thread. just too many great ideas to not be in the loop.
thanks to all for their contributions.
Old Mar 17, 2011 | 05:01 AM
  #794
stealthgoat's Avatar
stealthgoat
Those are a great idea, thanks for the link.
Old Mar 18, 2011 | 11:38 PM
  #795
traveler's Avatar
traveler
Shorty antenna for $1.39 :
EDIT: completion pics added.
https://www.hdforums.com/forum/touri...p-of-tape.html
~Joe
Old Mar 19, 2011 | 05:57 PM
  #796
TheStinger's Avatar
TheStinger
Default pre 09 2:1 add on stock headpipe with falsee mod
My addition for two things, 1-Using the newer style pipes on your older frame and 2-adding a falsee to keep the dual look using the old stock pipes from pre 09 models
https://www.hdforums.com/forum/touri...d-details.html
Old Mar 19, 2011 | 06:20 PM
  #797
TheStinger's Avatar
TheStinger
Default Garage door opener add on
Heres a suppliment for people wanting to add the GDO mod to their bike but...never want to change the battery again.
Use a LM7809 voltage regulator in place of your 9v battery. This device regulates the 12V from your "switched" side of your battery to the 9v that most garage dor openers require for use. Its small and SIMPLE to wire in. This will allow you to hide the remote anywhere forever and not have to replace a battery.
There are 3 poles on the bottom the the device, an input (12v+ pin 1) an out (9v+ pin 3) and a ground (- pin 2)
With the flat tab laying down, and facing away from you the pins are labeled as left to right 1,2,3
Heres a pic.
cost is around $1 dollar (how much was that 9 volt battery?) http://www.parts-express.com/pe/show...artnumber=7809
Simply solder the 12v from the SWITCHED side of your on off keyswitch to pin 1, ground to pin 2 (this also will jumper over to your garage door opener black wire) , and the output to your opener red wire.
Would always be a good idea to add .5 amp fuse on the 12V+ input wire.
Hope this helps everyone!
Old Mar 19, 2011 | 09:22 PM
  #798
Clint55's Avatar
Clint55
Safety back-up for tourpack cable. 550lb test parachute cord. .50 cents. Peace of Mind = Priceless.
Old Mar 19, 2011 | 10:24 PM
  #799
07FLHRCMarinePatriot's Avatar
Cool Radio Shack Siren Install
Here's link to a DIY with pics I just put together.
Friggin loud!!
https://www.hdforums.com/forum/touri...ml#post8070015
Old Mar 19, 2011 | 11:33 PM
  #800
wachuko's Avatar
wachuko
