Front fairing removal - 2011 RGC
Tools needed: a 1/2 wrench, T25 screw tip. Install fluid optional
Remove turn signals
Remove the 6 screws inside the fairing, remove the fairing by slightly pull out and up to take it off the hooks... unplug the headlight harness (push on both sides of the plug and it will come off easy).
If you are doing this alone, best to put a thick towel or something to cover your front fender...
Once you unplug the headlights put the fairing down on a nice piece of cloth (using a car cover in this case).
Green tabs that folks told me about to remove the headlight. But first the black trim around the headlights needs to be removed. Just use one of those flat nylon bars to push on the tabs and the trim will come out.
A lot of debate on taking the light housing out or not... for a newbie I recommend you do it, if only to learn how the fairing mounts to the hooks. Easier to do without the headlight in place. Plus you get an idea on how to replace light bulbs in the future (for 2011 you do not need to remove the fairing to get to the light bulbs, only remove the black trim and pull out the housing with the headlights).
Ready for when it is time to reinstall it...
[/QUOTE]Install as they say is... snap crackle and pop!
Fairing back in place, notice the two hooks that the fairing rests on.
Installing this back without removing the headlights, must be a pita to do....
There are six torx bolts, two longer than the others... the longer bolts go in the bottom of the fairing. Easy on putting all the bolts back. Do not overtighten. You really do not want the fairing tabs that hold the bolts to snap.
Hope this helps a newbie on the first time they take out the fairing. Cheers!
