HQ 500 c " Hurricane " Cams
Also talked to Zippers who's TMAT I like and TMAT support has been good. I currently run a D&D 2-1 and TMAT(thanks shooter64), have HD 103 jugs flat top pistons, normal to slightly agressive riding style, mostly highway, but also some city traffic in Miami.
Zippers Quote
577S cam 339.95
Gasket set 119.95
Adjustable Push Rods 149.95
Lifters (not required but recommended) 122.95
Total 632.80
Less lifters 509.85
HQ quote
500 hurricane cams 271.74
Easy install push rods 139.09
Pushrodconversion kit ( not required but makes job easier) 80.00
HD gasket kit 49.78
Total $540.61
W/O conversion kit $460.61
Based on the lots of posts and experience of the people on this forum I will go with HQ. Hoping to get close to 100/100 hp/tq with flat curves.Going to attempt the install myself, do I need the pushrod conversion kit based on your experience?. Kevin also gave advice about alignmentr and filing off any burrs on tensioner, said this cam will be good if I do headwork later.
The HQ cam is the same one I'm using in my build, and it's a great cam but I would think it might be a little "small" for a 103 build. In my 95" build listed in my signature, it's making about 100tq/97hp and the torque is very flat and wide.
Another one to consider is the Woods TW-6, it's a bolt-in cam and is very well known to produce flat torque curves.
The EZ-install pushrods make the whole job much easier, that way you don't have to remove the gas tank, rocker box covers, and rockers to change cams. I used the S/E EZ-install pushrods with great results...........they are $130 at your local dealer and you can get them cheaper with the X-mas sales coming up.
Steve
On the pushrods you can use your stock ones (double check with Kevin) but will need to remove the rocker covers to do that. I personally chose to go with the HD set of adjustable pushrods as they include the rocker covers for $130 shipped from Surdyk. The part number is 17997-99A. I plan on cutting out my old pushrods and using the EZ install ones. This way I will not have to remove the tank and rocker covers.
Depending on your compression you may want to move up to a larger cam but as MUC said you will have to likely change your springs. I am installing this cam in a stock 96" motor. I was planning on doing the full HQ 103" build but this is saving me close to $2K and am hoping it will suffice for a year or two. I hate to rebuild a motor with 4500 miles on it.
Lastly not to hijack your thread can anyone confirm or deny needing new cam bearings for an 07 model. I understand the 88 motor required the bearings to be replaced as they were pressed in. Any other feedback on these cams. I did get a great reply from Boargaurd even though he wasn't estatic with the results.
Thanks and good luck.
On the 07 ($08) motors, when you do the 103, you may want to consider a set of the pistons Doug (@) HQ had made to address the "down in the hole" scenario that is a result of the slightly shorter rods. If you use HD flatops, you'll be leaving some compression (AND power) on the table. The HQ's (specifically for the 07& later) motors will bring the piston back up flush with the top of the jugs.
If it were mine, I'd be sure to do that.... or at a bare minimum I'd get a set of the really thin head gaskets they have also had made for the same issue.
Setup right, you'll be more than happy with the results!
They are inexpensipiston and it's just kinda like insurance to me.
What's that word??
LOL
Steve
Hooked on Phil-ontics! Combines normal verbage with motor parts in one running word.
Cuts conversation time in half!!!
details are in my signature line, S&S Cams and Wiseco pistons, but the best part is the torque curve, check out the graph, pulls like a mother!
[IMG]local://upfiles/33632/BB65FD6AC2284D6FACDCC6FFEE6DDCDD.jpg[/IMG]
