Harley Bluetooth
when you make a call, you use a phone book that it downloads from your phone, voice dialing you say the phone number, it repeats then you say dial or nake recognition, you say tamara, it says tamara, you say dial and it calls tamara....
pretty simple..
I answer the phone when i get off the bike
Thanks
Rabid
As for installation, it was relatively easy. you need to remove the seat, tank console, outer fairing, and tour pak liner (if equipted). The box mounts to the side of the tourpack, and you cut out the liner to accomodate it. I have the tour pack wall organizer, so it still covers the Bluetooth unit. Note, you cannot have the Bluetooth along with the removeable tour pack kit.
The cable lays out along the frame and over the Gas tank, into the fairing on the right side of the bike (Passenger Side?
). Then the tricky part: you need to purchase an adapter cable for $82.50 from HD, to connect to the Bluetooth harness (it plugs into the CB harness), and you need to disassemble a couple of the modular connectors, remove the waterproof nylon pin inserts, and add the loose pins on the end of the Bluetooth Cable. It is something that you need the wiring diagrams for the shop manual to reference. A little confusing the first time, but not that difficult, if you take it slow, and make sure that the inserted pins are well seated in the connectors.All that said, it works fantastically. I too, need to be available on cell phone, so without it, I would not be able to ride as much. Also, I can keep in touch with the family when riding / touring far from home. You just have to be careful with the dialing, I use the voice prompts for the common numbers, and concentrate on your riding, not the conversations. Better to be not paying attention to the phone call, then the other way around. As for noise reduction, no one can tell I am on the bike, unless I really get on it (my reinharts are LOUD), at cruise like 75mph, no one can hear any noise. Really slick.
Good luck on the bluetooth....
