CENTER STAND
Old Dec 16, 2007 | 09:39 PM
kpb46's Avatar
kpb46
Default CENTER STAND
I would like to put a center stand on the Ultra. I have seen some but theylook awful when in the up position. The arm/lever used to raise the bike sticks out way to far. Anyone know of a stand that looks good up
Old Dec 16, 2007 | 10:01 PM
Plunk's Avatar
Plunk
Default RE: CENTER STAND
Check out this one from Wheeldock. I have seen it on an Ultra and it looks pretty sharp. Chrome or black. http://www.wheeldock.com/prod_EZ.asp
Old Dec 16, 2007 | 11:06 PM
zenwhipper's Avatar
zenwhipper
Looks like a good one. But the video they show of how easy it is to get the bike up on the stand, has the bike slightly uphill on a driveway when the stand is deployed. This gives slight momentum in favor of the bike, so I wonder how easy it is tho truly get it up on the stand.
Scott
Old Dec 17, 2007 | 06:40 AM
grbrown's Avatar
grbrown
Depends what you want the stand for. I have a Harley front-mounted show-stand on mine which is reasonably easy to use on level ground, tucks up under the foot-boards. Both wheels stay on the ground and the feet are wide apart.
I park the bike on it inmy garage and on 'safe' parking elsewhere. Can't remove either wheel using it, but it is useful for most other servicing.
Old Dec 17, 2007 | 06:55 AM
kpb46's Avatar
kpb46
I don't think I am interested in a "display stand" And as far as how hard it is to use....I had two Goldwings so I can put ANY thing upon a side stand. I am just concerned about the look while in the up (off the stand)position. I don't want a big dorky handle sticking way out from the side of the bike
Old Dec 17, 2007 | 07:04 AM
btefft's Avatar
btefft
Pardon my ignorance, but does the biggest stock Wing weigh more than the biggest stock Harley?
Hack
Old Dec 17, 2007 | 07:57 AM
kingultra's Avatar
kingultra
I have the Wheeldock on my Ultra and love it.
I is very simple to raise the bike! I took me a couple of times before I figured it out.
Old Dec 17, 2007 | 08:03 AM
ultraultra's Avatar
ultraultra
Just something to consider... If you have, or plan to install, the HD oil cooler, there is a warning that it won't work with a center stand. It's a mounting interference problem. JMO.. but an oil cooler is more necessary than a center stand.
Old Dec 17, 2007 | 08:07 AM
2ForTheRoad's Avatar
2ForTheRoad
Stupid question: How stable are Wheeldock center stands? I'm sure you want a level area to use a center stand, what else should you consider when using one? Obviously I don't have one, but the I've looked at the Wheeldock model and may add one in the future.
Old Dec 17, 2007 | 08:15 AM
peddler's Avatar
peddler
Yes it does. '07 Goldwing 856lbs. dry weight,
'08 Ultra 814lbs. Honda doesn't, as yet,publish the dry weight of an '08 Wing. Not sure why not.
