Trouble starting when hot
Old Dec 23, 2007 | 06:05 PM
Merlin's Avatar
Merlin
Default Trouble starting when hot
This ones a new one on me???
I have a 03 FLTRI. I just added95" jugs, .030 cometics,SE flat tops cast, 203cam with a baseline 105EV100 SERT map. Now when the bike is cold it starts fine. When the bike is hot and Istart itIget a cough, jerk and what sounds to possibly be a starter grinding noise. This grinding noise is worrying me. It usually takes 2 or 3 times to start up.No problems when it's cold only when the bike is warm.
Any thoughts?
Old Dec 23, 2007 | 06:29 PM
choochoo's Avatar
choochoo
Default RE: Trouble starting when hot
Recheck your map.
You're running higher compression, this can cause a premature ignition of the fuel air.
so recheck that and the timing.
sounds like a fuel problem.
Jerk, clunk, starter grind.....
sounds maybe like the fuel air mixture is igniting too soon. cylinders that are completely warmed up will sometimes tend to do this is warmer climes.
Then the premature F/A ignitiing will actually push a piston down sooner and faster than the starter can keep up with it. Thus giving the bendix (jack shaft assembly) the grinding noise.
Old Dec 23, 2007 | 07:24 PM
eglidetrike1's Avatar
eglidetrike1
I second that reply.
Old Dec 23, 2007 | 07:38 PM
SpikeCT's Avatar
SpikeCT
you have compression releases to assist in starting?
Old Dec 24, 2007 | 06:56 AM
Merlin's Avatar
Merlin
ORIGINAL: choochoo
No sadly, I didn't do compression releases.
It's a fairly mild build pretty much a stage2 95"/203.
Kinda late to do 'em now.
Got 300 miles on the bike since the build. Iput in the stock SERT map:
MY02-05 Touring and MY01-03 FLSTSi and MY05 FLSTSCi (with Touring Style Exhaust)
1550 Stage 2 FT 203 Stk105EV100
Are you suggesting to check the timing?
I was thinking 'bout doin' a dyno at 500 miles.
Would that be able to correct thejerk, clunk, starter grind?
Old Dec 24, 2007 | 07:39 AM
SpikeCT's Avatar
SpikeCT
I would be checking the starter, gears also... Make sure you haveen't broken or worn any teeth. It's never to late to add compression releases. it would take what maybe 2 hours (thats being generous) to remove your heads. Definetly check the starter and gears tho..... Better safe then sorry!
GREENOHAWK69
EVO
25
Jun 20, 2018 09:34 AM
plod1966
Sep 18, 2017 03:04 PM
Keithhu
May 9, 2017 06:38 AM
Skippy97
Jan 8, 2013 03:53 AM
Superfly3176
May 18, 2012 04:20 PM
