WHAT IS THIS THING?
Old Dec 24, 2007 | 09:11 PM
profinish's Avatar
profinish
Default WHAT IS THIS THING?
I was riding today with a buddy on a '08 Street Glide and noticed there was some kind of stabilizer linkage bolted from the front cylinder head to the frame. I never noticed that before... I'm sure its there to cut down on vibration. I don't have it on my '07 RG... does that mean that there was a problem with vibration on the 07's?
Old Dec 24, 2007 | 09:14 PM
lp's Avatar
lp
Default RE: WHAT IS THIS THING?
They moved the front stabilizer up (it used to be at the bottom of the engine under the oil filter). Does it help with vibration...don't know.
lp
Old Dec 24, 2007 | 09:15 PM
Jim Dawson's Avatar
Jim Dawson
They moved it to make room for the 6 gallon tank.
Old Dec 24, 2007 | 09:23 PM
rocknrod's Avatar
rocknrod
The 08's have one at the bottom and the top in the front of the engine.
Old Dec 24, 2007 | 09:37 PM
MACK's Avatar
MACK
rocknrod is correct. Itis a further measure to reduce vibration and is called an engine vibration dampner. There was no specific problem with the 07 bikes.Just another improvement by HD to make their product more comfortable.
Old Dec 24, 2007 | 09:45 PM
lp's Avatar
lp
The original poster is talking about the Front Stabilizer Link. It is not there to dampen vibrations. It's made of metal not rubber.
It was moved from the lower position (under the oil filter by the front motor mount) to add stability. Some say it helps stabilize the engine better in the frame and helps eliminate rear sway that some earlier models experienced.
And there is only one front stabilizer link...not two...read it here (page 8):
http://www.coastriderschapter.nl/200...%20Touring.pdf
lp
Old Dec 24, 2007 | 10:05 PM
Badfinger's Avatar
Badfinger
I think you guys are saying the same thing differently:
Roget's New Millennium™ Thesaurus - Cite This Source - Share This
Main Entry:[/b]
stabilize
Part of Speech:[/b]
verb[/i]
Definition:[/b]
brace
Synonyms:[/b]
balance, ballast, bolt, brace, cool, counterbalance, counterpoise, equalize, fasten, firm, firm up*, fix, freeze*, maintain, ossify, poise, preserve, prop, secure, set, settle, stabilitate, steady, stiffen, support, sustain, uphold
Source:
Roget's New Millennium™ Thesaurus, First Edition (v 1.3.1)Copyright © 2007 by Lexico Publishing Group, LLC. All rights reserved.* = informal or slang
Main Entry:[/b]
dampen
Part of Speech:[/b]
verb[/i] 10[color=#666666][size=3]11
Definition:[/b]
spoil
Synonyms:[/b]
allay, check, chill, cloud, [URL=http://thesaurus.reference.com/browse/cool]cool
Old Dec 24, 2007 | 10:23 PM
colaSG's Avatar
colaSG
They moved it forward to the front of the head to make room for the fly by wire servos.
Old Dec 25, 2007 | 05:42 AM
chornbe's Avatar
chornbe
Wow. Fun thread. Who's next to spin the "wheel of wtf" and give an answer?
Old Dec 25, 2007 | 08:23 AM
PhilM's Avatar
PhilM
Actually, it's used for engine / tranny alignment with respect to the chassis.
They've been there all along, but have been between the front & rear head ~ attached to the top of the bracket that the horn hangs from.
