PCIII and throttle position %, how do I know?
Old Dec 30, 2007 | 01:34 PM
Rhubarb's Avatar
Rhubarb
Default RE: PCIII and throttle position %, how do I know?
ORIGINAL: iclick
Rhubarb, where've you been, buddy? I saw a few posts you've made recently, but you disappeared for a while. I see you're still loosing the race to the kid on the Softail.
You know the drill... work, home, work work work, home, etc... [&:]
Things have slowed down a bit, so I get to come back.
I guess the summer treated you well with your tuning? How did the timing changes work out?
That kid is damn fast! I'm thinking of putting some cams in the R-.50 to catch him, but Harleys just run circles around my sport bike.
Old Dec 30, 2007 | 02:16 PM
iclick's Avatar
iclick
ORIGINAL: Rhubarb
I'm a relentless tuner, which means I work by the seat of my pants and keep stabbing at it in search of perfection, never quite finding it. I would really like to get an A/F gauge, but the useful ones are too expensive--so I'll continue with the intuitive approach. I went from 1a to 1h on my first map, then 2a to 2h on my second, seven changes for each, and just installed the trick Fuel Moto Rush baffles and am on 3c now. It's running well, heat is under control, and mileage is about as good as I think this bike will get. I also have no problems with detonation.
Last summer I advanced the timing 5° in the cruise range and heard detonation only once, but didn't see a change in mileage, so I changed them back to zero. On this most recent map I have it advanced 3° in the cruise range and so far no problems. This might need to be changed in summer when things heat up, but for now no ping.
Last summer I installed a PC multifunction hub and map switch, which allows me to switch between two maps on the fly. This has been a good option, as I can run extra lean for mileage and switch to the original rich map at any time, like when it gets hot and slow in summer traffic.
Old Dec 30, 2007 | 06:01 PM
Rhubarb's Avatar
Rhubarb
Wow, that is a lot of testing.
That module you bought would drive me nuts. I'd be forever switching tunes.
I wonder if you could adapt a couple wide band O2 sensors to some type of logging software.
There are basic circuit boards with computer chips (basic stamp comes to mind) that you can write your own simple code for.
It could easily log the data from an O2 sensor.
Old Jan 1, 2008 | 10:58 PM
iclick's Avatar
iclick
ORIGINAL: Rhubarb
The PC multifunction hub will supposedly accept analog info from the stock O2 sensor, and the LCD display will log that info, but I don't have the display and am too cheap to spend $300 for one. There must be a rational limit to experimentation, and that crosses the line. Fuel Moto has a chart on their site that translates the voltage output of the stock O2 sensors into an A/F ratio, but I'm not sure what input voltage the sensors need. The sensor outputs 0-1V, so does that mean it expects a 1V input, and if so how do you implement it. Also, I understand the O2 sensor output changes many times per second and that it is difficult to see the readout on a voltmeter since it vacillates so much. I would be interested to find out what my A/F is at various speeds, and if you can figure it out be sure to let me know.
There are many A/F gauges out there, but the good ones that show numerical A/F ratio are expensive (>$250), although there are cheaper units (~$50) that give you a generalized readout, like "lean," "stoich," "rich," etc.--but that is worthless to me.
Old Jan 2, 2008 | 09:41 AM
Rhubarb's Avatar
Rhubarb
0-1v eh?
Hmm, that sounds like a NB sensor, but it's been while since I looked at that stuff since my bike doesn't have sensors and i gave up my dreams of performance on my truck.
I think it's going to cost around $250-300 almost no matter what once you get into connectors, cables, a logging method, etc... but you never know.
I'll ask some friends for their input.
Old Jan 2, 2008 | 09:45 AM
swipter's Avatar
swipter
ORIGINAL: iclick
ORIGINAL: swipter
Thanks iclick, I think the tweaks I have been making, although helpful for about 1.5 mpg are just a tad high for TP%. I was thinking I was higher in the percentage. I will go back and retweak as soon as I replace my power supply for the computer. Thanks for the help, all.
Concentrate on 5-10%, where you can lean it quite a bit, but keep it not-quite-so-lean at 20%. Going too heavy on the leanness at 20% may cause a flat spot, but just try it and go by the seat of your pants. If you start getting some surging at light throttle when cold, you may want to back off a bit. I went with -10's in most of the cruise range for a while and had some surging when cold and hesitation on one occasion, so my latest tweak is richer with -5's, and the surging is all but gone. This may be the sweet spot with these Rush mufflers with the custom Fuel Moto baffles.
Which baffles do you have and what does your map look like? Attached is my before (3a) and after (3b). Keep in mind that 3a is an advanced map, tuned for each cylinder individually, so the other cylinder will look a bit different. I changed 3b to the same values for both cylinders, however. I also may change the "10" and "9" values at 20% to "5" and see how it goes. I don't think it needs to be that much richer than 10% at that point, but at 20%/3k you could justify more fuel, as at a cruise this would be about 80 mph in 6th gear.
BTW, keep in mind that the PCIII interpolates between settings. IOW, if you have "0" for 10% TP and "10" for 20%, it will run "5" at 15%, etc.
[IMG]local://upfiles/4327/942D5C6EE0984014A02E1F9B795C6C75.jpg[/IMG]
If you are in 6th at 2500 RPM and slow down, down shift to 5th and still at 2500 RPMs, is it reasonable to say that you should still be at the same TP%?
Great chart BTW. More knowledge for me to use on my PCIII.
Old Jan 2, 2008 | 01:20 PM
iclick's Avatar
iclick
ORIGINAL: swipter
All other factors being equal it would be higher TP in 6th because there is more drag the faster you go. I was running about 12-15% at 80mph, 10-12% at 70, and ~8% at 50-60.
Well, I changed it yet again to the chart I sent you via PM. The only change was the "10" and "9" at 20% were changed to "5" and "4". No change in performance, so that's good. Looking at the original map I couldn't see running that high at those points. I want it to richen up a bit at higher highway speeds, like over 70 mpg, as it will heat up at these speeds.
Old Jan 2, 2008 | 01:22 PM
swipter's Avatar
swipter
I never thought about drag...good point.
Old Jan 2, 2008 | 01:23 PM
iclick's Avatar
iclick
ORIGINAL: Rhubarb
0-1v eh?
Yes, it's NB. WB works on 5V, I think. Need to find out what voltage input the O2 sensor expects in order to output 0-1V. I suspect it is 12V and as a thermistor the sensor is reducing it, but I want to be sure.
VTwin-Goodies
Jun 26, 2009 12:00 PM
SC-Longhair
Jul 4, 2008 05:42 PM
ezlife
May 18, 2007 01:08 AM
coolmac
21
Jan 18, 2007 10:03 AM
HarleyWood
Exhaust System Topics
Jan 2, 2007 03:10 AM
