Andrews Roller Chain Drive Cam Conversion
Old Dec 30, 2007 | 02:53 PM
dw2169's Avatar
dw2169
Default Andrews Roller Chain Drive Cam Conversion
Does anyone run this setup ANDREWS-ROLLER-CHAIN-DRIVE-CAM-CONVERSION-KIT-HARLEY and what do you think of it? Does this help the cam tensioner problem?
http://cgi.ebay.com/ebaymotors/ANDRE...mZ370009425982
Old Dec 30, 2007 | 03:16 PM
dawg's Avatar
dawg
Default RE: Andrews Roller Chain Drive Cam Conversion
Check with "Sleeps In Trees" (Vic) here on the forum. I believe he just did the conversion. Yes it does help as it is the new tensioner system. It also has the updated cam plate whereas you do not have to press the bearings in. If you want gear drive and have no excess crank runout and don't mind a little gear noise, then I would go gear drive. However, if you have crank runout that is out of spec and/or like quiet valve train then the conversion is the way to go.
Old Dec 30, 2007 | 03:23 PM
masterblaster's Avatar
masterblaster
Disclaimer, I am not even close to a good source of info on this subject.From what I seen on my tensioners a couple days ago,an 07 with 13 k running hard in high heat and Miami traffic, I think they fixed the tensioner issue, there was a little rub mark in the outer tensioner but it was very little, the inner wasdam near perfect.From what I understand the 06 and prior tensioners were spring tensioned so the tensioner had pressure on it all the time the 07 and later are hydraulic and are tensioned withoil pressure from motor speed. So from my experience only with the 07 only I would say it is a logical fix, if there was one needed, and pretty good engineering by the MOCO.
Old Dec 30, 2007 | 04:39 PM
dw2169's Avatar
dw2169
Thanks for the input, I think I will go with Andrews 26 gear cams unless the endplay is too great. I just don't trust the chain drive yet but this may be the way to go in the future if the new style holds up. I'm deaf enough that i won't hear any extra noise anyway.
Old Dec 30, 2007 | 05:05 PM
jack49's Avatar
jack49
Also a good idea to upgrade the oil pump at the same time.
Old Dec 30, 2007 | 08:31 PM
duke76's Avatar
duke76
I am in the process of upgrading my 05, but am waiting on the cams from American Classic Motors, they said it could be up to another 5 weeks, everyone that has done the conversion that I have heard from has been very pleased, I was going to go gear but my runout was to much. Make sure you check that before you order your cams .003 is absolute max, and dont even think about putting them in if you have more than that or it will sound awful and you can end up with busted cam gears which will turn your engine into a boat anchor faster than you can say crank runout. After 2002 the moco quit using timken bearings so it is far more likely that your runout will be higher and more likely out of spec if your ride is newer than 02.
Old Dec 31, 2007 | 07:56 AM
Dalton's Avatar
Dalton
The conversion is a good deal. It also comes withthe newer style high capacity HD oil pump and new chain and tensioners. I am putting my engine back together, have 12k miles on the tensioners and putting them back in, no wear whatsoever.
Old Dec 31, 2007 | 08:40 AM
jaymcgil19's Avatar
jaymcgil19
I've got about 8k miles on the coversion and am pleased with it. Easy diy install for under a $1000 for everything including lifters and adj pushrods.
Old Dec 31, 2007 | 07:12 PM
notlost_nc's Avatar
notlost_nc
I'm running the 26N with the conversion on my '05. I like this system better than I did the gears. I had .002 runout and didn't like listening to the noise the gears made. With this '07 oil pump my pressure is now around 50. It's pretty quiet...I'm really satisfied with it. Besides the Andrews cams all other parts are from H-D.
Dixie Dreg
Mar 2, 2011 06:35 AM
Tanker2
Exhaust System Topics
Sep 22, 2010 05:53 PM
RickyB
May 16, 2010 10:15 PM
Shadowryder55
Jul 11, 2009 04:36 AM
BUSTERK
Mar 15, 2009 08:44 PM
