Fan Kit for Touring Models?
Old Jan 7, 2008 | 04:38 AM
Abnmarine's Avatar
Abnmarine
Default RE: Fan Kit for Touring Models?
I've been using the same model. It works pretty good and looks much better than the HD model.
ORIGINAL: Burglar56
I have the Lenale fitted to my 2003 Roadkingand if you switch the fan onearly it will stop the engine getting hot enought to burn your leg, I also prefere the Lenale for looks over the huge Harley fan as it looks just like an airwing horn cover.
Old Jan 7, 2008 | 05:03 AM
sleepman54's Avatar
sleepman54
ORIGINAL: The Old Man
I will wait to see how things are after it gets warm this summer. I have the parade mode enabled when I picked her up. Lot of money...just take back roads and see the sights.
I've got the parade mode on mine and it really doesn't do much for you. By the time it kicks in the bikes already running hot. It only is going to kick in when you're at idle. And it's made mine stall in traffic because of dropping the rpm, when I go to roll back on the throttle it will stall out.
Old Jan 7, 2008 | 05:37 AM
rocknrod's Avatar
rocknrod
Thats the one Lenale Im thinking of getting. And a Dual Horn kit mounted behind the left saddle bag.
Old Jan 7, 2008 | 09:20 AM
iclick's Avatar
iclick
I decided against the fan although I do think the concept is good. I've heard reports about short lifespans, plus the high price is a deterent, especially if you must replace it every so often. Being an electrical component HD probably only warrants it for 90 days, a year at the most, so you probably won't get much sympathy if it dies on you prematurely. Instead, I decided on an oil cooler, synthetic oil, and a well-conceived map for my EFI controller (PCIII). The oil cooler is less efficient when not moving or moving slowly, but does work somewhat through convection. Last summer my max oil temperature was 230°, and that only occurred twice on very hot days in heavy traffic. Normal temperatures in summer are 210° while moving. These are easily within the acceptable range, but on my bike I wouldn't want them going any higher.
WI Bob
Touring Parts
Jul 4, 2012 06:53 AM
pargenz
Nov 8, 2010 11:28 AM
Eric in chicago
Touring Parts
Jun 18, 2010 07:53 AM
stratplexi
Touring Parts
Dec 14, 2009 03:43 PM
atexn4christ
Mar 14, 2007 03:23 PM
