dyno
Old Jan 8, 2008 | 03:28 PM
mrdeere1959's Avatar
mrdeere1959
Default dyno
i have a new 08 ultra. i had the 103 stage II put in. the dealer told me they dont like to dyno until after 1000 miles. at 1000 miles the dealer did service.i asked about the dyno tune. they said my bike with sidecar will not fit on there dyno. does it need to be dyno tuned? help.
dale in casper
[IMG]local://upfiles/26778/ED8C19AB8D2B4DC2880ACBCF43259674.jpg[/IMG]
Old Jan 8, 2008 | 04:24 PM
pled55's Avatar
pled55
Default RE: dyno
i'm no expert but from what i do know if you have the stage 2 set up and have
a fuel management device you may want to have it checked for lean afr so you don't damage your engine
or if you want the last ounce of power from your 103 you would have to get it dynoed
the can probably take the sidecar off for the dyno
Old Jan 8, 2008 | 04:46 PM
Blacklion213's Avatar
Blacklion213
Default RE: dyno
I had problems finding DYNO/TUNER also. I talked with PCIII manufacturer and they gave me a list to select from. They were ATV/Motorcycle places. I selected a SportsCenter that supported the PCIII. I could not believe how much Harley had the trike leaned out (it was a standard download that was close to my trike configuration). You may also be able to take your sidecar off for the DYNO/TUNE.
[IMG]local://upfiles/25017/E35671A79FE840A0B60516D7B8EE1C5A.jpg[/IMG]
[IMG]local://upfiles/25017/2CF88882A2B446AAB6A46E4596764AA8.jpg[/IMG]
Old Jan 8, 2008 | 09:59 PM
eglidetrike1's Avatar
eglidetrike1
Default RE: dyno
I ran into the same problem blacklion ran into, here is how I solved it. I ask around for a good independent shop found a guy who was more than willing to work with me with a trike. We installed a T-max ECM and downloaded a generic program for what my bike had done to it. I ran the bike for several weeks and got back to him on how I thought it was running. After several weeks I took it back and had him lean out the air fuel mixture in the upper RPM range in 4th and 5th gear cruising range to get a little better gas mileage.
Old Jan 8, 2008 | 10:04 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: dyno
Dyno... Will fine tune the engine for Max Performance (Horse Power & Torque) and Fuel Delivery\Mileage - Through Out the Power Curve
Hoping that they did install a SERT along with the Engine Up-Grade???
bigdawg06
General Topics/Tech Tips
Jan 21, 2015 01:07 PM
anubisss
Sep 17, 2009 04:36 PM
YellowHawk
Mar 17, 2009 05:00 AM
Booey424
Mar 18, 2008 09:02 PM
Elusive 1
Feb 2, 2008 10:33 PM
