Remove outer fairing, pull radio.
Then pull ignition
Then remove inner fairing cap
But before you do any of that, you should get the HD service manual because it explains how to do all of it.
Then pull ignition
Or you could cheat like I did. Loosen the bottom 2 clamp bolts and they'll move. But youshould have the manual as you'll still have to remove the ignition and inner fairing cap.
