Amplifier, what fits inside the fairing
Old Nov 4, 2010 | 10:53 PM
  #31
bamarider's Avatar
bamarider
Originally Posted by mcdowell25
I too have the Arc mini 125 and it's a great amp. As said above sometimes I had to reset (turn the bike off/on) the amp but that is because the amp remote start connected to the cigarette lighter and comes on when the ignition is turned on and if I start the bike too quickly the amp shuts off (quick reset) to protect itself against a power surge. so the answer is to wait until the radio actually comes on and then start the bike.
Mine wasn't plug and play but it's not that hard to buy the stuff that you need to wire in the amp.
Good luck!
I have the Hog Tunes amp and it really sounds good but I have a similiar problem. I have to crank the bike immediately when I turn the ignition on. If not the amp goes crazy. I have to turn the ignition off and on. They know the problem and have been very helpfull but still no fix.
Old Jan 23, 2011 | 08:20 AM
  #32
Orange09Glide's Avatar
Orange09Glide
From what I am reading the Hawg Wired 2 channel expandable is the way to go. I have a 2 Channel on my bike and wish I would have went with the expandable from the beginning. I want to add speakers in my lids but to do so I will have to shell out more money to upgrade my amp.
Old Jan 23, 2011 | 08:21 AM
  #33
Orange09Glide
Does anyone have any experience on the Hog Tunes 4 channel amp. It seems really inexpensive for 4 channel power?
Old Jan 23, 2011 | 08:33 AM
  #34
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
J&M will be coming out with a 4 channel amp in March. y personal opinion is that this amp will stomp all over the Hawg Wired and HogTunes amps. Their 2 channel amp and 7.25 speakers are the best setup I have heard by far on a bagger.
Drew
Old Jan 23, 2011 | 09:11 AM
  #35
vickers1's Avatar
vickers1
Originally Posted by agapsdiver
I would be cautious of an amp that in it's specs doesn't include output power at distortion under 1%.
**Output: 300w Peak Power (150 Watt x 2CH), Power Draw: 2 Amps
This amp probably puts out maybe 50 watts per channel that you could actually use.
Also, there is only so much bass that any 5 1/4" speaker can make. I would seriously consider a kit with 6 1/2" speakers and the adapters to get as much bass as you can.
Notice I didn't mention the J&M 7 1/4" setup. That's because I checked them out in the J&M booth in Daytona and they sounded like crap.
I have heard the Arc Audio setup with the 6 1/2" coaxial speakers and they sound really good.
http://store.arcaudio.com/products/p....0.0.0.0?pp=8&
Old Jan 23, 2011 | 09:24 AM
  #36
vickers1's Avatar
vickers1
Originally Posted by RancherPete
3) I have a 2000 Ultra Classic with four speakers but it seems that I would most likely have to power just two of the speakers since this is the way the other kits seem to do it for some reason. Although I suppose that one could bypass the fader and just power all four with this 4 channel amp (again, not sure how that works).
All of the good quality amps will play at 2 ohms with no problems.
If you got a good 2 channel amp and tied the front and rear 4 ohm speakers together (1 front and 1 rear per channel) that would have 2 ohms going to each channel of the amp. The amp would handle it well and actually put out more than the rated power.
I wouldn't spend the extra money and take up the extra space of a 4 channel amp just for the sake of a front and rear fader.
Old Jan 25, 2011 | 03:24 PM
  #37
pit1600's Avatar
pit1600
I'm looking on the Alpine KTP-445 wich give 100Wx4. It's a small amp wich seem to fit on the top of the radio. It will not be probably the best amp but it will double the power and i think it will work well with my Focal's
Old Jan 25, 2011 | 04:10 PM
  #38
Harleypingman's Avatar
Harleypingman
Peter,
Typical amplifier installations involve disconnecting the wires connected to the speakers and reconnecting them to the hi-level inputs of the amplifier; then, additional wires are used to take the amp outputs to the speakers.
On your Ultra, you can use a two-channel amp for the front fairing speakers and leave your rear speaker wiring alone retaining the fader control.
If you used a four channel amp, you'd simply use the front and rear speaker wiring on the bike connected to the hi-level inputs on the four channel amp and run new speaker wires from the amp outputs to the speakers; again, retaining the fader control of the radio.
As for the RCA converters (these convert the hi-level signal from the radio to an RCA-type connector for plugging into the amp rather than using the hi-level inputs on the amp), they aren't needed on most quality amps e.g. Arc, J&M, Hogtunes, etc.
If you do install an amp, the speakers driven by the amp should be impedance matched to the amp; i.e. if the amp is 4 ohm (as most are), the speakers should be 4 ohm. The OEM speakers on your bike are 8 ohm so installing an amp will usually require a speaker change as well.
Finally, you can buy heavily discounted new, but discontinued, HD four-channel amps for your bike on Ebay that mount under the tour pak.
Carl
Old Jan 25, 2011 | 04:31 PM
  #39
18BKLR's Avatar
18BKLR
Originally Posted by dandfire
LOL I got that same Mitzu mini-amp from Ebay, hoping to power a pair of polk, marinecert. speakers to put in my lower fairings, to use with an i-pod. Haven't tackled the project yet,are they that shitty that it won't work?
I have the 200W version and It rocks like a champ. Mounted with velcro on top of the head unit. Couldn't cough up the price for some of the otheres. If it makes the summer it will stay in. If not I will shop around again.
Old Jan 25, 2011 | 04:50 PM
  #40
JMJOHN's Avatar
JMJOHN
Sponsor
best sounding amp I have ever heard right here ,,,, http://www.youtube.com/watch?v=6xIcWjYISRE ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
