Amplifier, what fits inside the fairing
Old Jan 22, 2008 | 02:58 PM
BAGTHIS's Avatar
BAGTHIS
Default Amplifier, what fits inside the fairing
Of a street glide? I am trying to mount a 2 or 4 channel amp on top of the stereo in the fairing of an 08 streetglide. Does anyone have any suggestions for this, or a place to get he hawg wired amp for resonable? Any suggestions would be helpful, and puting a amp in the bags is not an option for me.
Old Jan 22, 2008 | 03:04 PM
etrader's Avatar
etrader
Default RE: Amplifier, what fits inside the fairing
www.hogtunes.com amp sells for about $200.
Old Jan 22, 2008 | 03:09 PM
Slope's Avatar
Slope
I am on a tight budget and went on the cheap. Nevertheless, the system sounds pretty good. Here's what I installed:
ANitro-BMW43 4 channel 300 watt amp ($30.00). The specs are:
[*]Dual gain control [*]Plug in harness [*]Built-in double side PCB [*]Low THD [*]Low power consumption [*]Low heat emission [*]LED power indicator [*]Turn on/off by remote (I connected it to the live wire on the lighter)[*]RMS Power Handling : 45W x 4 [*]Max Power Handling : 75W x 4 [*]THD @ 4ohm : 0.8% [*]Channel Separation : 55dB [*]Frequency Response : 20Hz-20kHz (What the human ear can hear!)[*]Input Impedance : Low level 10k ohms [*]Dimension : 4.5" x 1.6" x 3.7" (WHL) (Small enough to install over the radio inside the fairing)
I also installed a
Nitro (BMW-CV) 2 Channel Hi-Low Impedance Converter($15.00) with a set of Polk Audio db521 marine rated 5-1/4" speakers ($100), because the Harley radio does not have RCA outputs. Total cost=$145.00 + 1 hour of my time to install. As good a sound as you can get from 5-1/4" speakers! As a matter of fact, I had to reduce the gain on the amp to remove distortion at high volumes. Works like a champ! PM me if you want further details.
Old Jan 22, 2008 | 03:11 PM
Slope's Avatar
Slope
I also did not cut any of the wiring on the bike. I made some connectors. This way, I can always remove it and connect everything the way it came from the factory.
Old Jan 22, 2008 | 03:53 PM
PhilM's Avatar
PhilM
Hawg-Wired!
Check with Bart (Shooter64).... he can hook ya up!
Old Jan 22, 2008 | 04:30 PM
agapsdiver's Avatar
agapsdiver
Check out this one:
http://www.uniqcycle.com/150_Watt_Cu..._p/ucs-amp.htm
Old Jan 22, 2008 | 05:55 PM
BAGTHIS's Avatar
BAGTHIS
So hog pro or hawg wire are the two most popular, any opinions on how they sound? I am trying to push the 5 1/4"s in the fron and a pair of 6x9's in the saddle bags.
Old Jan 22, 2008 | 06:03 PM
BAGTHIS's Avatar
BAGTHIS
SLOPE,
So give me your honest opinion on this amp. I just bought a amp that looks very similar to this off of e-bay a MITSU or MITZU MT (or something) 75 and it is junk. It's only a two channel, but it has less power than the deck!
Old Jan 22, 2008 | 06:35 PM
XXXRacing's Avatar
XXXRacing
I tried the blaupunkt THA275 PnP and it was garbage. Returned it. Hawg-wired is on it's way.
Old Jan 22, 2008 | 07:20 PM
mrbuck's Avatar
mrbuck
xxx i just put a tha275 on mine. what problems did you come up with so i know what to look for or if i should return mine too. so afr seems o.k.
