tire and balance question
Old Jan 23, 2008 | 10:07 AM
dstockton's Avatar
dstockton
Default RE: tire and balance question
I've been changing my own tires for 15 plus years cause I go through a lot on my sport bike. I just changed both tires on my 06 Ultra.
A trick I've always employed the first time I pull a wheel on a new bike is to check the balance of the wheel before I mount a tire. If it's off, I apply JB Quick to the light side inside the wheel until I get it balanced. Makes for less weight needed later.
On my Ultra, both wheels were balanced and needed no adjustment. Placing the dot at the tire valve the rear needed no weights at all, it was spot on, the front needed about 20 grams, less thanan ounce.
The front has less tread than the rear but wears down much slower. I still had plenty of tread on the front but saw a few cracks in the tread at 20,000 miles. This is the second rear on the bike and that's a pretty good ratio, change the front every other rear on a bagger.
Old Jan 23, 2008 | 10:22 AM
dbird's Avatar
dbird
I use the dyna beads front & rear Michelin tires.
Old Jan 23, 2008 | 11:28 AM
Troy.R.H's Avatar
Troy.R.H
I also change my own tires using a friends NoMar tire changer. Like Jinks, I check the wheel for the heavy spot. You'd be surprised how many times it's not the valve stem. Once I locate the heavy spot on the wheel, I mark it and line up the dot on the tire with that mark. I then also balance the wheel and tire together.
Old Jan 23, 2008 | 12:04 PM
lecomte38's Avatar
lecomte38
I've had pretty good luck balancing my own tires. just slide the axle in and hang it between 2 saw horses. The heavy side will be down. Spin it and watch. One spot will always end up down. Play with automotive stick on weights until there is no heavy side down.
Old Jan 23, 2008 | 02:21 PM
nwbobnw's Avatar
nwbobnw
I have done it both ways. Balancing is better.
Old Jan 23, 2008 | 05:25 PM
relli's Avatar
relli
well i just mounted the frt tire today. i have 4 ounces of dyna beads (2 frt and 2 rear) but havent installed them yet. i figured it was easier to add them after a test ride than to pull them out later. i realize i dont quite know what to look for in "out of balance" on a bike tire. IE: if the frt needs balance will i feel it in the bars or frt end like ya would a car?or does it transmit thru the frame / floorboards ect????
should i just go ahead and add the dyna beads with a "can't hurt anything" attitude????
Scudda
Jan 19, 2013 05:29 AM
DPete
Jun 6, 2011 10:50 PM
Ledgen
Mar 13, 2011 09:50 AM
k&j eglide
Apr 30, 2010 02:05 AM
earlehd
Mar 30, 2008 07:35 PM
