Like I said earlier, mine did it until I had about 80 miles on the clock. It first dropped from 1800 to about 1300 or so and around the 100 mile mark it was idling at 1000-1100. Don't know why, just glad I didn't have to go see the dealer to get it correct.
The fact that KJC stated "If I turn the throttle away from me then the idle goes down to 1000 rpm" means that the bike does in fact need to relearn a proper zero for the twist grip. The phenomenon he is describing is not the warm up cycle. The ECM thinks he is holding the twist grip open slightlyâŚeven though his hand may be off the throttle. When he rolls the throttle away from him, the twist grip voltage goes below the learned zero and the ECM returns the throttle plate to the idle position.
I am not sure why it learned an improper zero, but it has, and cycling the power 4 times should correct the issue...at least temporarily...if there is another issue it will return later.
In case you are interested, the ECM records the twist grip voltage on both sensors at every key offâŚassuming it is in the proper range. It stores 4 values for each sensor. To determine the value to use for zero, it throws out the high and low values and averages the two remaining.
Thanks for the advise. It worked. I left the engine on for about 5 minutes then I shut it down and restarted and let it ran for about a minute. I repeated the cycle for 5 times and the idle rpm is exactly at 1000. Thank you sir.
Electrical power. Make sure your run/stop switch is in the run position. Turn the main power on...wait 5 sec...turn off...wait 5 sec...repeat3 more times. This should be done with the twist grip in the idle position.
