squeak from engine when turned off?
Old Feb 1, 2008 | 11:11 AM
pled55's Avatar
pled55
Default RE: squeak from engine when turned off?
i have read something about this noise before
and i think the answer was there is something called
umbrella valves that make a noise simular to what your
describing .just a thought
Old Feb 1, 2008 | 11:24 AM
ricoman's Avatar
ricoman
Glad you posed the question. Thought I was hearing things.
Old Feb 1, 2008 | 11:48 AM
rotrager's Avatar
rotrager
My 01 RK did it, but haven't heard it from my 07 CVO Ultra. Go figure.
Old Feb 1, 2008 | 12:01 PM
peppi's Avatar
peppi
Don't think it's anything but induction noises from the air being drawn in on the last stroke when the engine is turned off.
Old Feb 1, 2008 | 12:13 PM
FX4's Avatar
FX4
Mine does the same.
Old Feb 2, 2008 | 04:10 PM
miacycles's Avatar
miacycles
We tracked down a "whistle" to the IAC opening a little as the engine shut down in an attempt to maintain idle speed. The air goes through it and whistles. You can change the pitch or even eliminate it for a while by cleaning the IAC with some intake cleaner.
Old Feb 2, 2008 | 06:27 PM
2008FLHP's Avatar
2008FLHP
mines sounds like popeye's pipe!...i'll go look it up but, what's an IAC?
found it--- IAC stands for Idle Air Control. It`s used to do exactly whatthe name implies.
The IAC should have no input on the popping. Normal IAC specs are 30 counts at idle hot/while stopped. AFR would be the leading factor when popping through the exhaust system is a concern. Run some real time data frames (record) andplay it back. Look at the data when the problem occurs and you should find your problem.
BombshellZ
Carburetor Related
Sep 1, 2016 04:21 PM
BEN-Z
Aug 19, 2014 07:00 PM
Red89
Dec 10, 2012 07:20 PM
On Deck
Aug 25, 2011 11:27 AM
hitone
May 17, 2008 03:11 PM
