ZUMO Powerlet Techmount quick disconnect
Old Apr 3, 2008 | 07:46 PM
  #31
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: ZUMO Powerlet Techmount quick disconnect
We have used Powerlet products for the past several years and many many bikes.
They have quality products, excellent Customer Service, and to top it all off their stuff is Made in America.
We have the Powerbar mounted on the left handle bar with a Legal Speeding Radar Box mounted on a Ram Quick Release mount using a pre-manufactured Powerlet Valentine Power Cable. Easy to remove should we need to stop for the night, or if the weather gets too bad.
Zuma 550 is going to be mounted on the RS of the Cop Glide, when the "tax stimulus check arrives".
Old Aug 24, 2008 | 11:55 AM
  #32
RangeRat's Avatar
RangeRat
Smile Thanks for this thread
Tagged.
Old Feb 22, 2009 | 04:02 PM
  #33
Woodchuck's Avatar
Woodchuck
Merlin,
Great set-up. They say imitation is the best form of flattery (or something like that) and I'm sure a lot of us will be copying your lead. I have a Zumo on the way and want to install a "quick disconnect" for the power and the cradle so I can swap it to another bike and for the reasons you said. I'm going to copy what you did except for hiding the wires in the handlebars. From what I had read, it sounds like Powerlet is quality stuff.
I've got a stupid question...make that two. It looks like the cradle is bolted to the stem plate in place of the Ram mount. How do you remove the cradle? Is the stem a slip fit so that the cradle and stem pull out of the Powerlet fixture? It looks like the stem could be rotated left or right but there is no up and down adjustment, right? I ask because I'm tall and don't want to have to scrunch down to see the screen.
The hardware is great looking but your installation makes it a truly professional job!
(DUH. I think the up and down adjustment is made when you install the Powerlet on the handlebar, no?)
Old Mar 7, 2009 | 01:39 PM
  #34
Merlin's Avatar
Merlin
Originally Posted by Woodchuck
Merlin,
To remove the Zumo Cradle I used the Techmount Accessory Quick Change Adapter $14.95. It is a quick disconnect with a small ball that locks the Zumo cradle into place on the riser plate.
There is no up and down adjustment on the Techmount riser. I personally used the Techmount 2 ˝ inch riser. I believe they have multiple taller sizes. The Techmount 2 ˝ inch riser puts the Zumo at the perfect height for me.
Old Apr 7, 2009 | 03:02 PM
  #35
lvnMyFB's Avatar
lvnMyFB
Default Info from Powerlet
A friend of mine ordered parts for a similiar install. Salesman asked to have the latest info about part #'s posted.
PKT-068 is now the PKT-90 or PKT-091 depending on the diameter of the bars.
<http://www.powerletproducts.com/product/handlebar-outlet-also-mounts-gadgets/347>
The techmount items are bundled here:
<http://www.powerletproducts.com/product/garmin-zumo-powermount-techmount/72>
Aparently the company has a new site and some of the links posted here earlier don't work.
Old Apr 8, 2009 | 06:47 AM
  #36
cycletrash98's Avatar
cycletrash98
I like merlen's clean install ..sweet!
Old Apr 29, 2009 | 09:24 PM
  #37
Badbagger's Avatar
Badbagger
Indeed, VERY clean. That's the way I'll prolly go on my new Nuvi when it gets here.
Old Jun 7, 2009 | 09:58 AM
  #38
rajvirdee's Avatar
rajvirdee
Looks superb but one question - can you remove the Techmount easily so that when you're riding without the satnav you just have the Powelet visible?
Thanks in advance...
Old Jun 7, 2009 | 12:32 PM
  #39
Merlin's Avatar
Merlin
Here is a pic with the bare mount Powerbar and Tecmount stem with the Tecmount quick disconnect removed. The Techmount stem screws firmly into the Powerlet Powerbar and is not designed for quick removal. Even though the "plate" shows, it is chrome and IMHO does not look bad.
Here is a side view with both the audio and the bluetooth using the standard helmet headset.
Old Jun 9, 2009 | 04:55 AM
  #40
rajvirdee's Avatar
rajvirdee
Thanks for the reply and advise.
Awesome job
SC_Compact
Sep 22, 2010 06:51 PM
ngoti8tor
Jun 10, 2009 01:44 PM
garys_ultra
Mar 9, 2009 06:25 PM
buckwheat
Nov 10, 2008 12:54 PM
Ace07FXDL
Nov 22, 2007 02:31 PM
