help with cam decision
Old Jan 18, 2006 | 11:20 PM
classicjade01's Avatar
classicjade01
Default help with cam decision
i have a 2001 electra glide classic efi with pcII, v&h dresser duals, sampson rolled thunder mufflers, and se air cleaner and i wanna go gear drive cams. my question is which cam should i go with considering my setup. i was thinking andrews 37g or 26g i dont know which would be better for my setup. and my other question is wiether or not to do a stage 2 download since i run MM efi or try to get a custom tune for my pcII. any feedback would be appreciated. thanks.
Old Jan 19, 2006 | 12:00 AM
YankeeBob's Avatar
YankeeBob
Default RE: help with cam decision
You may be better off with the TW26G in an 88". The TW37G works best at 9.7-9.8:1cr. The 26g will be a great cam for a basically stock motor. It will provide you with much better low/mid than the 37g. The 37G is a better cam for 95"-98" motors with head work. Have your heads street ported (BigBoys) and use the 26g and you will be a happy camper.
PS..Don't forget to have it tuned.
YB
Old Jan 19, 2006 | 06:03 PM
04RoadKing's Avatar
04RoadKing
I would go with S&S 510G cams. This cam works very well on stock 88" motors, and if you ever decide to bore out you cylinders and do some head work later on down the road the S&S 510G will still be useable.
Old Jan 19, 2006 | 10:40 PM
jeepster09's Avatar
jeepster09
26G
Old Jan 19, 2006 | 10:46 PM
YankeeBob's Avatar
YankeeBob
26G will also do very well in a 95"
bedelman10
Engine Mechanical Topics
98
Jul 21, 2016 07:00 PM
Madcop
Jul 16, 2014 10:36 PM
IDIDNTDOIT
EVO
Sep 25, 2009 11:55 PM
expolice
Exhaust System Topics
Oct 9, 2008 08:06 AM
rickrides
May 25, 2008 03:17 AM
