TWO FACE TAPE REMOVAL HELP PLEASE!!!!!
Old Feb 6, 2008 | 10:57 AM
mrblister's Avatar
mrblister
Default RE: TWO FACE TAPE REMOVAL HELP PLEASE!!!!!
Try a rag soaked gasoline, you might be surprised what that will easily take off.
Old Feb 6, 2008 | 11:20 AM
jakester's Avatar
jakester
GUN_WORKS Is the Wild Turkey For ME or for getting off the tape..LOL....THANKS.......JAKESTER..TIM
Old Feb 6, 2008 | 11:42 AM
DeJavu's Avatar
DeJavu
Gasoline and Acetone will eat your paint. Do not use them. Gasoline contains Toluene, a heavy solvent, real bad for paint.
Old Feb 6, 2008 | 11:53 AM
eglidetrike1's Avatar
eglidetrike1
I use Dental floss insted of fishing line and goof off, works every time.
Old Feb 6, 2008 | 01:59 PM
BillinNY's Avatar
BillinNY
[quote]ORIGINAL: gunnert
Start with a hairdryer to warm up the tape. Then take a piece of monofilament line (yes, fishing line) and tie it to two sticks/screwdrivers, or something like that. Once you have the emblem heated with the dryer, use the mono like a hand saw. The emblem should come off fairly easy. If tape is left on tour pak, peel off what you can with your fingers. Then purchase a can of adhesive remover from Home Depot (it is used to remove decals, etc) and use that to remove the rest of the tape.
+2 That's exactly how I remove badges affixed with two sided emblem tape.
Old Feb 6, 2008 | 02:06 PM
IronLegend's Avatar
IronLegend
Used 'Goo Gone' to remove the adhesive from the reflector on the rear fender of my Sportster when I was going to install the backrest sideplates. Took a wee bit of rubbing but worked very well.
Old Feb 6, 2008 | 03:41 PM
tarheelrdr's Avatar
tarheelrdr
HaHa been there-done that. Having been in the bodyshop business for 35 years, you're right on the blisters, on small jobs it seems to work pretty well though.
ORIGINAL: The Baron
I always just yank the emblem off with my fingers and then use my thumb to push the tape off bit by bit. After that I pop my blisters and sip a brew while I admire my handi-work.
Old Feb 6, 2008 | 03:50 PM
Potato_Potato's Avatar
Potato_Potato
Goo Gone and dental floss - Hay I don't fish alright.
Old Feb 6, 2008 | 04:34 PM
big_al's Avatar
big_al
Do the heating method then use the fishing line trick..then use some acrysol to remove the tape left....
Old Feb 6, 2008 | 04:36 PM
sharkeydude's Avatar
sharkeydude
ORIGINAL: outlaw0013
WD-40 will help remove it.
America's favorite remove all! I use it on everything.
