07 clutch cable
Old Feb 10, 2008 | 10:58 PM
frank1's Avatar
frank1
Default 07 clutch cable
anyone know if the clutch cable and gas cables for a 06 and down is the same [will it fit] for a 07. i havent taken the clutch cover off the bike yet and i am thinkn that there might be a difference in the cable ends. i have the extended pull back handle bar kit that was on a 2000 flht that i owened at one time , took it off when i traded it. the kit came with the clutch and trottel cables. the bar will fit ,but what about the cables. the dealer didnt know for sure they would just pull what ever part they needed from invertory and do the job . anyone know for sure
Old Feb 11, 2008 | 12:29 PM
twincam47's Avatar
twincam47
Default RE: 07 clutch cable
The clutch cable is the same for all tourers except the CVO's with the hydraulic clutch...Part # 38667-00.
Throttle Cables....are the same if it is from an electra glide to an electra glide.
There are 3 pull cables and 3 return cables listed for both year models and are the exact same part numbers for both years.
Pull Part # 56357-02
Return Part # 56358-02
Old Feb 11, 2008 | 12:38 PM
dawg's Avatar
dawg
For the extended pull back handlebar kit you would use the same clutch cable as for the TLE sidecar models which would be 38649-98 which is a +3 cable.
Old Feb 11, 2008 | 12:49 PM
twincam47's Avatar
twincam47
ORIGINAL: twincam47
OOPSS....my bad..misread the part numbers...
clutch 06 / 38667-00
lcutch 07 / 38667-07
I think this is part of the 5 speed to 6 speed difference.
Throttle Cable numbers are good
And Dawg's sidecar number is good through 06 but changes in 07 to Part # 38649-07
falconbrother
EVO
22
Dec 20, 2015 04:41 AM
oinker02
May 30, 2013 05:51 AM
rquest
Nov 30, 2012 05:36 PM
barkster99
Jul 12, 2009 10:31 AM
mooreto
Jul 31, 2007 10:44 PM
