HELP Ignition Lock Flht%$%$&*
Old Feb 13, 2008 | 08:22 PM
leohd's Avatar
leohd
Default HELP Ignition Lock Flht%$%$&*
I removed the ignition lock/fork lock, on my 2003 flht I don't have the harley tool the manual calls for some people on this forum said patience and a lil screwdriver , the best I could get after alot of trying and patienceis for it to work with the **** BUT if I put it in the off position and press down it locks the **** to where I can't turn it to the right untill I press the release on the bottom and release it. any help is greatly appreciated. Thanks
Old Feb 13, 2008 | 08:35 PM
LKHA's Avatar
LKHA
Default RE: HELP Ignition Lock Flht%$%$&*
make sure the collar is on correctly tab on the bottom facing the front and before inserting it I had to push the tab and rotate the key then drop it in then should beable to rotate it good luck hope it helps
Taildragger NC
Feb 28, 2013 08:08 PM
CrazyMC
Apr 28, 2009 11:30 AM
HDSTORMDANCER
General Topics/Tech Tips
Feb 28, 2009 09:51 AM
streetglide13
Feb 10, 2009 05:41 PM
user 5342924
Oct 11, 2008 03:39 PM
