blacked out front end question
Old Feb 20, 2008 | 08:12 PM
Chicago Spike's Avatar
Chicago Spike
Default RE: blacked out front end question
Those pegs come with the ability to take the top half off and you can pull the rubber pad out. Some pegs you can't get them apart and if you pull the rubber out and the rubber snaps, you have to buy a new set of pegs, you can;t buy the rubber only.
The signal stalks are easy too. You need a small screwdriver, like the size for eye-glasses. The screw driver you will stick in the holes above the pins and you will push up to release the pins in the plugs. You really need 3 hands for this, my wife helped with pulling the wires out while I worked on the pin release. Once you get the plugs off, the wires will pull right out. Make a diagram for replacing the wires in the right slots later
Old Feb 20, 2008 | 08:40 PM
kong00us's Avatar
kong00us
Thanks for the hints on the turn...sounds good...I bought some of the billet hyway pegs sold by harley..the round ones with the 4 rubber bands that are on the inside and outside of the peg..anyway to a heat gun and heated it just alitle and they came right off..no problem..if I was alittle smarterI might have looked a something more like yours but the ones I got looked like they would work easy.......got a couple torx type heads to do also...will the scratch when I try toput everything back...Thanks for the hints on the light I though you might have cut them or something..................thanks again
Old Feb 20, 2008 | 09:04 PM
Chicago Spike
Yeah, the torx heads will fill up with powder and you won't get the bit back in. I use either "Hot Spots" or I paint the smaller screws with a rattle can, and once in, I can touch them up with a brush.
Old Feb 20, 2008 | 11:22 PM
kong00us's Avatar
kong00us
hot spots???
Old Feb 21, 2008 | 12:30 AM
PapaTravis's Avatar
PapaTravis
Maybe he meant hot toppers, which are bolt covers???
Old Feb 21, 2008 | 05:07 AM
olgreydog7's Avatar
olgreydog7
ORIGINAL: Road King Kong
Do it all
Do you have pics of the completed bike yet?
Old Feb 21, 2008 | 07:24 AM
Chicago Spike
Yeah, Hot Toppers, or the like. They snap into allen heads and cover them in many colors. Kuryakyn.com has them
Old Feb 21, 2008 | 11:15 AM
ffchadbo's Avatar
ffchadbo
Hey Road King Kong
That front end looks sweet!!
Is that the PM Gasser? Did the brake rotors come like that?
Or did you powder coat them?
Nice Ride
Old Feb 21, 2008 | 11:37 AM
Chicago Spike
If you go with composite rotors like Lyndall, you can have the friction ring in black, the buttons in black, and coming soon, the carriers in black chrome. I'll post pics as soon as I get them
UltraSteveUSAF
2014-2024 Touring Models
19
Mar 6, 2015 09:54 PM
mimsboyce
Oct 9, 2012 09:56 AM
Warrior Redleg
Powdercoat & Paint
May 12, 2011 11:15 PM
Krazy8s
Aug 26, 2010 01:17 PM
MarksBOB
Jul 14, 2008 08:49 AM
