Help with accessory wiring??
Old Feb 19, 2008 | 11:19 PM
gdbro4's Avatar
gdbro4
Default Help with accessory wiring??
I have a 2007 Ultra Classic. I want to wire into the auxiliary/accessory 4 pin connector under the seat,which has a rubber plug in it. Does anyone knowwhat thepart number is for the connector and terminals that plugs into the factory 4 pin connector?? Please help?
Old Feb 19, 2008 | 11:24 PM
nmfxstc's Avatar
nmfxstc
Default RE: Help with accessory wiring??
Whatchya wana do? Trust us....your HD delaer has the connector (either a 12V charger/lighter thingy or a "Y" connector that gives you twooutlets....mo' betthuh we know what ya wanna hook up!
Old Feb 19, 2008 | 11:44 PM
gdbro4's Avatar
gdbro4
I'm looking to install lights into my "accessory" switch, so they can be controlled with the stock switch. Thanks.
Old Feb 20, 2008 | 12:20 AM
RADLINE's Avatar
RADLINE
Supplemental 12v Power Point
Easy to install power point allows an additional 12 volt power source for electrical accessories powered by a cigarette lighter type socket. Features a water-resistant cover with laser-etched Bar & Shield logo.
91843-97
Fits '94-later FLHR (except FLHRCI), FLT, FLTR, FLHX and FLHT models.
MSRP US $17.95
Old Feb 20, 2008 | 12:32 AM
Harleypingman's Avatar
Harleypingman
gd: I have the connector with wires attached that I didn't use when I installed the HD saddlebag spoiler/LED's. The connector plugs into the P&A Accessory plug you have. You could dissassemble my connector or simply splice your lighting wiring to the wires already in this HD assembled connector.
Send me a PM with your address and I'll send it to you--whatever that's worth to you just "pay it forward." You don't owe me a thing if you accept.
If you want to purchase the parts yourself, PM Dawg or TwinCam47. The harness I have is PN 70549-99 and from that part number they can give you the PN's for the Deutsch connector, rubber gasket, secondary lock, andsockets (femalewire terminals that go inside the connector)you'll need.
Old Feb 20, 2008 | 07:55 AM
FireAlan's Avatar
FireAlan
I just installed mine the other day to power a GPS mounted onthe handlebars. I cut and spliced the wires then ran them under the gas tank and up into the fairing. I mounted the accessory port into the empty gauge cup I had (FLHT Standard) by removing the cup and drilling the hole for the port, a nice and neat install. Where the wires can be seen by the neck, I wrapped the wires in auto store bought wire wrap.
Old Feb 20, 2008 | 08:34 AM
RonH's Avatar
RonH
Here's the one I used for my Boogey lights - 70264-94
[IMG]local://upfiles/9233/7D7D40946E364D5A934BC55C5587CF30.jpg[/IMG]
Old Feb 20, 2008 | 08:43 AM
twincam47's Avatar
twincam47
ORIGINAL: gdbro4
Plug Housing (1).....72114-94BK....MSRP 4.50
Plug Lock (1)........72154-94....MSRP .70
Wire Terminals-pins (4).....72191-94.....MSRP .60 each
Seal (1)....72195-94....MSRP .45
I would suggest having the dealership put this thing together in that it takes a special crimper tocrimp the deustch connectors onto the wire.
One other thing...there are four wires in the plug on the motorcycle....you will need to test light those wires to make sure you get the one that is routed to the accessory switch on the dash. If my memory serves me correctly there will be a constant voltage pin (switched-works with ignition on), a brake light pin, the accessory pin that you are looking for and a ground.
Get the dealership to crimp wires on to all four pins and assemble the plug for you...then use only the wires that you need.
Old Feb 20, 2008 | 10:24 AM
twincam47's Avatar
twincam47
ORIGINAL: RonH
70264-94 MSRP 14.95
Also you would have to know what pins this plug is contacting on the bikes plug....you would also have to cut the 2 leads off to get tothe 2 wires that are on this plug. Otherwise you would be buying more plugs to tie into the 2 lead pigtail.
Old Feb 20, 2008 | 10:31 AM
RoadKing_Al's Avatar
RoadKing_Al
Just bought the other day.
[IMG]local://upfiles/46449/E0FFF27E18D94D7B87CA8CB2CC6EBBB2.jpg[/IMG]
