The headunit getsthe bike speed signal from a white with green stripe wire; if you check the Base Audio Connector (that big plug attached to the rear of the radio), you should see it. That wire is also there for the cruise control. It's part of the bike's main wiring harness and gets its signal from the vehicle speed sensor via the ECM.
I don't know how to diagnose the VSS, but it may be the problem.
