Volume control.
Old Dec 28, 2012 | 11:48 PM
badger401's Avatar
badger401
Default Volume control.
I am having some issues with the volume control on my 08 Ultra classis. I can turn it down but not up. I thought is was the volume switch on the handlebar so I replace it and that seem to fix it for a few weeks, now it is acting up again. Sometimes it will work, sometimes not. I am beginning to think it may be a connection inside the fairing in where the harness connects to to the audio system or the audio system itself. Anyone else had this problem? If so, what was the fix.
Old Dec 29, 2012 | 12:57 AM
jjnoble's Avatar
jjnoble
You could check the pins on the 23 pin connector (I think 23), make sure they are seated and not corroded.
Old Dec 29, 2012 | 01:37 PM
Peculierboy's Avatar
Peculierboy
I had the same problem, almost. I could turn the volume UP, but not down, at least not all the time. I thought it was the switch as well, so I bought a new one to swap out. Prior to doing that project, my whole HK radio died and I replaced it with a Biketronics/Sony system. My volume control works fine now. It may be a connection or it may be your radio.
Old Dec 29, 2012 | 01:40 PM
Renold's Avatar
Renold
Do you have your auto volume set to extra low so when your stopped it is not real loud? Just a thought.
Old Dec 29, 2012 | 01:47 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You are on the right track. It sure sounds like an intermittent contact....either a broken wire, shorted wire, poorly seated wire to a pin, or something along those lines. The fact that it did work when you installed the new switch says the radio is not broke. So it's somewhere between the volume rocker switch and the radio. I would suspect something is shorting in the switch housing if it worked for a while after you changed the switch.
Old Dec 29, 2012 | 02:07 PM
dawg's Avatar
dawg
Another thing to check is the version of the software. An update may or may not fix it. Either way, it can't hurt to update the software anyway.
Old Dec 31, 2012 | 12:10 AM
badger401's Avatar
badger401
Default Well, now it's working.
Went out to the garage today and turned it on, volume works fine. Had planned on pulling the front of the fairing off and tinkering with the connections, guess I'll just leave well enough alone for now but will check those connections. Thanks for all the input. Curious about the "software update". Need more info on this please.
Old Dec 31, 2012 | 08:35 AM
dawg's Avatar
dawg
http://www.harley-davidson.com/en_US...bmLocale=en_US
Old Dec 31, 2012 | 09:15 PM
badger401's Avatar
badger401
Default Thanks!
I will give that a try tomorrow!
just plain john
Audio Systems
Jan 27, 2024 10:26 PM
mccstevie
Apr 23, 2013 07:51 AM
hillcountryflt
Audio Systems
Jan 22, 2012 08:40 PM
VandalENG
Nov 12, 2010 07:25 AM
bobmurdy
Apr 11, 2008 08:50 AM
