Are you talking about the long whip antenna? I bend mine down and forward to a clip which holds the little ball end. One of my friends has made a wire antenna inside the fairing which works OK. The optimum length for FM is 31 inches which is what most car antennas are.
I went thru all the radio stations before cutting mine down to see how it would effect the reception. I wrote down the number of stations that came in. I then cut it from 47" down to 36". There was no difference in recption. I then took it down to 30" and found I only lost about 4 stations. So I left it there.
I also tried the 13" piece that I cut just to see how it would come in. It was bad! Didn' t get much reception at all.
knowing very little about wave propagation and the ideal antenna length for varying frequencies, I googled it. So here's the FCC's version of an answer on "ideal antenna length for FM transmission":
A quarter-wave whip is not a compact antenna. At 1 Mhz, in the AM Broadcast band, one quarter of the wavelength is about 246 feet, or 75 meters. At 100 Mhz, in the FM Broadcast Band, it is nearly 30 inches
(75 cm). This dimension continues to shrink at higher frequencies, being nearly 3 inches (7.5 cm) at 1000
Mhz. A simple formula for the quarter-wave (in cm) is: 7500 divided by the freq. (in Mhz), or for inches:
2952 / freq. (in Mhz). This formula is only a starting point since the length may actually be shorter if: the
whip is overly thick or wide, has any kind of coating, or is not fed close to ground.
I have been using two of the rubber whips from the local auto parts store, one for the CB and the other for FM, when the tour pak is on. I have cut the original wire antenna down and use it when the tour pak is off.
