Shift ROD & Shift LEVERS
Old Feb 2, 2006 | 04:54 PM
bountyhunter's Avatar
bountyhunter
Default Shift ROD & Shift LEVERS
I spread my shift rod out to the max and set both shift levers as low as they can go (almost flat).A lot less free play, shifts are quicker and crisper and I barely have to lift my heel/toe to shift. The bike even feels even more responsive, shifts smoother and requires much less effort. My left boot is happy! [sm=smiley33.gif]
Old Feb 2, 2006 | 05:15 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Default RE: Shift ROD & Shift LEVERS
Are you still using the stock POS shift rod or did you go with something stouter?
I replaced the stock with the lowest price plain one that uses the ball joint after buddy had the stock one come apart late at night while out on the road.
Took quite a bit of zip ties, duct tape, and tie wire to get him home.
Old Feb 2, 2006 | 05:19 PM
bountyhunter
Still using the stocker. I check the whole shifting assembly from time to time to make sure everthing stays snug.
Old Feb 2, 2006 | 05:32 PM
AK_Hog_Herder
He had about 10K on the stock on and the rod separated from the pivot at one end.
But then he is into being a bit forceful when he shifts. [:@]
RomeoTango
Jun 29, 2018 02:35 PM
champipple
Apr 2, 2015 05:48 PM
SOCALHD
Screamin Eagle CVO Models
Oct 15, 2014 10:46 AM
Chazmanian
Jun 20, 2009 11:31 PM
bountyhunter
Mar 28, 2006 02:26 AM
