I think using the stock drivetrain you can roll a 150 wide. Stock should be 140.
I have a 150 Avon Venomon my Road King.
- The cheapest alternative I have found to go wider is to go with a chain drive (instead of a belt), and (I think) the fender is wide enough to allow you to run a 170.
I had a 150 on my '04 RK Custom, when I replaced it you could see where it rubbed ever so gently. There was a shiny strip around the entire tire.. I went with a 140 (which I had already planned on doing) when I replaced it due toit's increased load rating.
