Bird Chirping
Old Mar 26, 2008 | 09:46 AM
Harley Dave69's Avatar
Harley Dave69
Default RE: Bird Chirping
Would brake pads chirp only at a certain rpm?
Old Mar 26, 2008 | 10:01 AM
granddad's Avatar
granddad
silicone spray, wet the drive belt good. Then go for a ride. If squeek stops, then you know it is the belt.
Old Mar 26, 2008 | 10:11 AM
Harley Dave69
I will give it a try Granddad will keep you posted, Thanks again
Old Mar 26, 2008 | 10:16 AM
Neil's Avatar
Neil
Rineharts are famous for "chirpping". I would be willing to bet that is the source.
Neil
RDMC
Old Mar 26, 2008 | 10:27 AM
FLHT's Avatar
FLHT
I also have a little bird chirp, I also have Rineharts, I have had this chirp ever since I put the Rineharts on. There has been many talks about " The Rinehart Chirp". Only at certain RPMs and only when under a slight to medium load on the engine. Heavy load on engine it goes away and and no load it is not there. Mine is coming from the right side, I think (sound can travel and do some strange stuff on a bike). I have yet to pull the baffles and try to tighten them, which has been some peoples fix. I really bugged me at first, but not so much any more, I just go faster or crank ZZ Top a little louder
Old Mar 26, 2008 | 10:28 AM
Silverearl's Avatar
Silverearl
Check your timing cover. I had mine come loose and it bugged the hell out of me too Until I found it.
Old Mar 26, 2008 | 10:33 AM
Harley Dave69
Thanks alot guys I will keep you all posted, I am checking the baffles and retighten
Old Mar 26, 2008 | 10:41 AM
harleykris's Avatar
harleykris
Got a similar chirp here, but I can only hear it when I have on my half helmet. (I know, wear a bigger helmet). I have a D&D Fat Cat, but can't really tell if it's coming from the left or right side. I tried silicon on the saddlebag mounting rubber and the exhaust mounting brackets but so far no luck. I'll try the belt today before I head out and see if that helps. At first I thought it was the saddlebag lids, so I pushed on them while I was riding but no luck. Sounds like rubber rubbing against metal.
Old Mar 26, 2008 | 10:47 AM
CREEPSHOW's Avatar
CREEPSHOW
Couple other possiblities, check the tightness of the head bolts at the exhaust, did you use new gaskets? Also, the air coming into the A/C could whistle. Dunno what it sounds like but just ideas here. [sm=confused06.gif]
Old Mar 26, 2008 | 11:26 AM
Odd Job's Avatar
Odd Job
I had the same bird chirping, drove me nuts, I sprayed silicon too, didn't work, thought it was the drive belt, used the belt dressing, chirping was still there...dealer couldn't find it.
Frustrated I put my bike on a lift, did a walk aroud the bike and shook everypart imaginable.I shook the left side pipereally slow and heard a faintchirp.........since silicaon didn't work I sprayedWD-40 on the same saddlebag mounting brackets rubber bushings...chirping stopped! had'nt had a chirp out of the bike again. Keep both runner bushings well lubed...still no chirps. Hope this works for you.
