Check this out!
Old Mar 29, 2008 | 05:38 PM
2005UltraNC's Avatar
2005UltraNC
Default RE: Check this out!
Check the other exhaust joints (like where the slip on's mount to the header pipe.
Old Mar 30, 2008 | 01:08 AM
DiegoKing's Avatar
DiegoKing
Here's what I know...the intake gaskets are now new, the exhaust is tight at all joints and has new gaskets at the heads, this pop has been going on for a while now and is VERY loid when it happens, sounds like a gunshot. The tip of the exhaust is pretty black and sooty but no burn marks. I am going to try to figure a way out to retune it but don't know which direction to take.
Old Mar 30, 2008 | 01:24 AM
1Harleyrdr's Avatar
1Harleyrdr
Cold air & hot gas makes pop
Old Mar 30, 2008 | 04:29 AM
harleyrobert4's Avatar
harleyrobert4
I bet ifyou ride out in the early evening, when the pop happens, you shoot large flames out your tail pipe. Your are definatly out of tune, you probably need a new map on that sert or a tune up of some type. Everyonehere is giving great advise to you, unfortunatly it will probably boil down to the sert or some tuning issue in the end.My reasoning is from I had a very simular problem a few years back and all it took was to richen things up a bit.
Old Mar 30, 2008 | 08:15 AM
Paniolo's Avatar
Paniolo
ORIGINAL: DiegoKing
Diego,
Your 2001 is a Magnetti-Marelli (M&M) FI bike. Your tuning options are Power Commander orHD SERT for M&M. The other more expensive options include the Zippers T-max kit (converts you over to Zippers Delphi by replacing your ecm and throttle body), or the Daytona Twin-Tech (converts you over to OEM Delphi) Those last two are expensive ventures, but good proven units that come with closed loop tuning. Some folks may suggest TFI/DFO/Race Fuelers too. I never had much tuning success with those. On my 2001 I've had the Power Commander, TFI, the HD SERT for M&M, and now the Zippers Kit.
The SERT for M&M is what I would start with. If you need a good tuner, I know of a couple up here in LA.
Mark
Old Mar 30, 2008 | 08:19 AM
1flhtk4me's Avatar
1flhtk4me
The gaskets may look like hell,but did you test for intake leak before replacing?
Wouldnt an intake leak create an erratic idle?
Old Mar 30, 2008 | 08:21 AM
DaveMK's Avatar
DaveMK
Pop or backfire? Stock exhaust? Mine has been popping/rumbling on decel for over 24,000 miles. I like it.
gsxrboy96
EVO
16
Jun 4, 2012 07:28 PM
vickon
Feb 20, 2010 06:57 PM
hd99flhpi
Exhaust System Topics
May 8, 2009 04:42 PM
Arizona
Oct 4, 2008 01:07 PM
cadillac
Jun 10, 2007 05:52 AM
