Air Temp Gauge
Old Apr 7, 2008 | 11:08 PM
JStephens53's Avatar
JStephens53
Stage II
Default Air Temp Gauge
I recently purchased a 97 ultra...on the dash there is a air temp gauge....my question is what is it for and what should it read?
Thanks
Old Apr 7, 2008 | 11:41 PM
nmfxstc's Avatar
nmfxstc
Default RE: Air Temp Gauge
The primary function of that gauge is to fill a hole and balance the look of the dash panel/inner faring!
It shoud read exactly what the air temperature is utside (you can check the weather channel to validate!), but in reality, tells you what the temp is inside your faring.
It's a useles POS HD stuck in there instead of giving us something useful so they can sell the useful stuff (oil temp, compass, etc.) aftermarket!
Old Apr 7, 2008 | 11:45 PM
White Knight 04's Avatar
White Knight 04
Boy you are new, (but welcome) and the gauge reads the outside temp...I.E. if it is 60 degrees out it will read 60 + it isn't real accurate.....
Jer
Old Apr 8, 2008 | 12:01 AM
acftdr's Avatar
acftdr
It's basically a meat thermometer, and you're the meat. When it reads 110 degrees, dinners ready! You're thighs should be a golden brown...
Old Apr 8, 2008 | 02:44 AM
Arizona's Avatar
Arizona
The temp gauge as it comes from the factory does not read accurately because of where the sensor is placed (it's inside the fairing so generally reads 10-20 degrees warmer than the actual temp, esp in summer).
If you remove the front of the fairing and move the sensor to the outside (drop it down below the fairing and mount it to the area below and outside) and it will read pretty accurately and therefor at least be a useful gauge at least. Many folks go with an oil temp gauge and get rid of the air temp gauge.
Old Apr 8, 2008 | 05:32 AM
jbhawley's Avatar
jbhawley
+1 on nmfxstc comments. POS HD product.
Old Apr 8, 2008 | 06:03 AM
UltraDave's Avatar
UltraDave
ORIGINAL: Arizona
+1 on what Arizona said. I moved it and it does read fairly accurate.
Old Apr 8, 2008 | 06:32 AM
jbmss's Avatar
jbmss
Its good for knowing the temperature inside the fairing.
Old Apr 8, 2008 | 06:51 AM
xmeter's Avatar
xmeter
Mine was so far off I replaced it with the oil temp gauge... At least now I have some useful information.
Old Apr 8, 2008 | 07:18 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Do a search. You will find aLOT of posts on this. Also, welcome to HD Forums.
