Saddlebag Filler Strip Kit HELP
Old Apr 8, 2008 | 07:47 PM
hounddogg's Avatar
hounddogg
Default Saddlebag Filler Strip Kit HELP
Just purchased the Saddlebag Filler Strip Kit matched to my color of my bike. Went to put on and cant get them to line up. When I try to install them the top hits my mounting bracket for my bags. Does anyone have these on there bike and did you have the same problem? I took off the spacer behind my bag mounting bracket and they fit fine but the bags will not fit then. I have a 07 Roadking Classic.
Old Apr 8, 2008 | 08:08 PM
SPARKY01's Avatar
SPARKY01
Default RE: Saddlebag Filler Strip Kit HELP
had the same problem on 08 eg classic. it wasn't that the strips were wrong but the saddle bag mounts needed to be adjusted. i moved them a bit but then the problem was gettting the twist locks lined up again. the biggest interference i had was at the top. i bent them a little bit to clear. was a little nervous about it but you can't see anything once their on and the bags are bag on. just take your time and walk away for a minute to think what you need to move before you actually loosen it up. like i said, i had more of a problem getting the bags mounts adjusted again...ride safe
Old Apr 8, 2008 | 08:15 PM
skltr's Avatar
skltr
The top tab on the filler panel should rest on the bag bracket. Had to adjust both the front and rear bag brackets after the install to get both pins aligned.
Old Apr 8, 2008 | 08:30 PM
Superglide 04's Avatar
Superglide 04
Strips won't work with a custom or a classic RK, the bags hit because of the different shape on the back of the bag.
Old Apr 8, 2008 | 08:41 PM
hounddogg's Avatar
hounddogg
when I take the spacer the filler strips go on great but the bags will not fit on then The website and book says they fit but there is no way. I know my stealer is going to give me a big hastle about returning. even though they said they would fit and order them for me.
cgmartine
Jun 25, 2013 10:25 AM
speakerfritz
Jul 20, 2011 08:21 AM
SOLOLUCKY
Sep 1, 2010 11:01 AM
masterblaster
Dec 25, 2007 05:44 PM
Pastor John
Feb 8, 2007 01:59 PM
