Setting up new PC111
Old Apr 9, 2008 | 03:36 PM
rickoshay45's Avatar
rickoshay45
Default Setting up new PC111
I am considering the Rush/Fuelmoto Power pack from Jamie. As I live in an apartment complex, I don't want to make a lot of noise. When setting the Throttle Position Sensor the bike must be running at idle to set the idle position. How long do you need to keep it at 100% and can this be done at the old rev limits or should it be done at the new higher limits?
[/align]
Old Apr 9, 2008 | 04:17 PM
skratch's Avatar
skratch
Default RE: Setting up new PC111
the bike does not need to be running in order to set the 100% throttle. use the battery adapter, and make sure the ignition, and the kill switch are both on (this one killed me....)
Old Apr 9, 2008 | 04:31 PM
Jinks's Avatar
Jinks
If you set the throttle positions with the motor running you don't allow the motor to go to 100%, only the throttle. You first set the 0%, then simply open & close the throttle *QUICKLY*! The motor will only gain a few hundred rpm. You don't want to let it get wide open with no load on it!
Old Apr 9, 2008 | 04:39 PM
bstewart71's Avatar
bstewart71
It would wise to set it with the motor off with ignition and kill switch on as previously posted.
Old Apr 9, 2008 | 04:44 PM
rickoshay45
Thanks all for the input. I was thinking of taking the bike and my laptop down the road to an empty parkinglot.
[/align]
gww303
Jul 5, 2014 01:15 PM
12hdrk
Apr 13, 2013 08:57 AM
kingkingking
Jan 27, 2010 04:21 AM
roadrider
Mar 9, 2008 04:59 PM
ezlife
May 12, 2007 11:34 PM
