Installed XE7r HID conversion
Old Apr 12, 2008 | 01:41 PM
ragingbull's Avatar
ragingbull
Default Installed XE7r HID conversion
I work rotating 12 hr shifts so I'm either going home at 0430 or going to work at 0400 every day. I've been wanting more light since I pcked up my Streetglide a couple years ago. This really was an easy installation(didn't need to remove fairing) and the difference in light was worth the price tag. If anyone else decides to do it the instructions that come in the box are generic. You can get a much better set online at Kuryakyn's website.
Old Apr 12, 2008 | 01:54 PM
bulldogmoe7's Avatar
bulldogmoe7
Default RE: Installed XE7r HID conversion
i have been thinking about doing this myself.
Old Apr 12, 2008 | 05:49 PM
ragingbull's Avatar
ragingbull
The only thing that was kindof a pain was the allen bolts seemed to be mixed between metric and standard heads. It could have been the plating possibly but I ended up buying a metric allen set to do a couple. Not a big deal though...
Old Apr 12, 2008 | 05:51 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
had the same allen head problem with a kuryakin travel pack rack rounded one out till i figured out they were metric heads
Old Apr 12, 2008 | 07:18 PM
Ram's Avatar
Ram
[sm=ttiwwp.gif]
would be nice with a picture!
Old Apr 12, 2008 | 07:25 PM
rocknrod's Avatar
rocknrod
ORIGINAL: Ram
[sm=ttiwwp.gif]
And or a Link.
Old Apr 12, 2008 | 07:54 PM
Badfinger's Avatar
Badfinger
WOW, kind of expensive:
http://www.kuryakyn.com/products.asp...ey&ci=3500
Ride well,
Jim
Old Apr 13, 2008 | 06:40 AM
Ram's Avatar
Ram
So this kit is a Lo and Hi beam lamp all in one. It looks nicer then the H-D HID with the dual bulb set up that I'm running and as for cost its at least $100 bucks less expensive.
I think its a deal, want a trade?
Old Apr 13, 2008 | 07:10 AM
FastHarley's Avatar
FastHarley
Former Sponsor
The HID I sell: [ul][*]is Hi/Lo with no changing of handlebar wiring[*]needs no extension ring[*]bike looks exactly the same as before[*]both HID draws the same current (2.4 amps/35 watts) which is 1/2 that of a 70 watt halogen bulb[*]light spread and length has the same characteristics in either case (HID kits)[*]needs no special lens as the stock one (HD or after market such as Adjure) works the same as your pattern currently.[*]has a much smaller Digital (advanced) Ballast than the Motorola pictured[*]designed for your lens, does not need to have the ballast in the enclosed headlight bucket (traped heat in the case of the enclosed headlight bucket) or mounted near the headlight, it can mount anywhere such as behind or under the battery box or oil tank (it is very thin)[*]has the same bulb H-4 Hi/Lo and extended life expectancy of 2-3 thousand hours[*]has a money back customer satisfaction guarantee in the customers (your own) opinion provided by me personally[*]has a one year warranty supplied by me personally[*]has live installation support 7 days a week during wakening hours or view in PDF on my site[*]sells for less than $250 delivered[*]many HDF members are reference to both quality of my service and products. Do a search.[*]I support this site [/ul]
Old Apr 13, 2008 | 10:37 AM
captsam54's Avatar
captsam54
danielsternlighting.com
Not to throw mud on a sponsor but Daniel's HID system is awesome,.. I used it on my 07 JK wrangler and there is a world of difference..!!
Also a lot of good info on the diff between US and European driving lights and laws, light values etc.
Well worth reading if nothing else..!!!
cosshog
May 18, 2014 05:40 PM
RickK
Apr 10, 2014 08:15 PM
mikeallenbrown
Apr 17, 2012 03:37 PM
RAVEN1776
Mar 14, 2011 04:24 PM
fixxr
Oct 27, 2009 06:52 PM
