installing floor board extensions without a jack?
Old Apr 12, 2008 | 02:34 PM
wild hog's Avatar
wild hog
Default installing floor board extensions without a jack?
Just ordered the Soos 1inch extentions for my 08 SG.Has anyone installed them without using a jack? Dont have a jack and know I will eventually get one but wanted to try and getaway doing this project without. Any help appreciated. And props to Soos great guy to deal with!
Old Apr 12, 2008 | 02:46 PM
yogi167's Avatar
yogi167
Default RE: installing floor board extensions without a jack?
I didn't use a jack and had no problems.
Old Apr 12, 2008 | 02:51 PM
rochkes's Avatar
rochkes
I actually have a jack but had no desire to use it when installing my floorboard extensions. Just follow the directions. It will warn you that when you do the left side, you are removing 2 of the 4 bolts that hold the kick stand in place.
I REALLY like my floorboard extensions. Makes the ride much more comfortable.
Dennis
Old Apr 12, 2008 | 02:52 PM
timhdfl's Avatar
timhdfl
Just installed mine last night. No jack needed.
05LowRider's Avatar
05LowRider
ORIGINAL: yogi167
+1
Just carefully removed the two bolts from the jiffy stand bracket without disturbing the bike and causing any movement until I had reinstalled those bolts. The rest can be reached and done without any need to lift the bike.
Old Apr 12, 2008 | 03:01 PM
mrsr71's Avatar
mrsr71
No jack here [8D]
Old Apr 12, 2008 | 03:16 PM
spence222's Avatar
spence222
Jackless on this job....
Old Apr 12, 2008 | 03:19 PM
Hugh Jass's Avatar
Hugh Jass
Question: Are the floorboard extensions that you are talking about for the rear floor boards? And if so, where did you get them? I just put on RH True Duals and the left pipe is awfully close to the Missus' leg. I need to extend that out for her. I also have an 08 SG.
Old Apr 12, 2008 | 03:21 PM
wild hog's Avatar
wild hog
Thanks for the reply's guys. Will tackle it tomm.
Old Apr 12, 2008 | 03:24 PM
outlaw0013's Avatar
outlaw0013
Extensions are for the driver floorboards. Just lay on the floor to install a jack would actually be in the way.
