im Stuck, Need advice
Old Apr 19, 2008 | 05:34 PM
bkhanson's Avatar
bkhanson
Default im Stuck, Need advice
I have a 03 Roadie, and was planning on moving the spotlights to the most forward hole. How does a person do this. I have twisted and pulled to no success. I took apart the spot it self thingking there would be a nut inside, but nothing. I took apart the lower amber assy and there is a nut has the wiring inside in the upper part. I coudln't get at it and looking for some advice from other who have tackled this task. What gets me the most, is everything on the harley is basically simple engineering, what Jap designed this for HD,
Old Apr 19, 2008 | 08:57 PM
choochoo's Avatar
choochoo
Default RE: im Stuck, Need advice
Remove the lower 1/2 which is the turn signal.
I believe the wire unplugs, if not you can cut it and use spade connectors.
HD makes a special socket and so does snap on.
But you can make it your self.
buy a cheap 9/16 deepwell. cut a slot from the nut end up the side (just one
slot), I used a die grinder.
wide enough for wire to fit in. Make 1/4 or so turns and reposition socket.
finish diassembly, move where you what and reassemble.
Old Apr 20, 2008 | 09:12 AM
bkhanson's Avatar
bkhanson
Thanks Chooo, that's what I was afraid of having to do. I was really hoping I had missed somthing and there was an easier solution.
Thanks again
Groucho1
Aug 31, 2015 01:58 PM
fffffish
Apr 28, 2012 12:03 PM
paulies46
Sep 16, 2010 03:02 PM
Arizona
Jun 13, 2007 07:08 PM
scooterbooter
Jan 2, 2006 01:36 AM
