Maxi Fuse Removal?
Old Apr 28, 2008 | 03:30 PM
bucs012's Avatar
bucs012
Default Maxi Fuse Removal?
I have done a lot on my bikes changing parts out, battery, bars etc. Never have removed my Maxi Fuse before doing something.Never had any issues, but KNOW I am suppose to do it.My manual tells me so.
Is this really a big issue?
Old Apr 28, 2008 | 03:35 PM
LarryInEastTn's Avatar
LarryInEastTn
Default RE: Maxi Fuse Removal?
Evidently not, as I've never removed mine either. Then again, we are probably risking "serious injury or death", by not doing it. The manual tells us so.
Old Apr 28, 2008 | 05:14 PM
bucs012's Avatar
bucs012
Ha. I thought maybe I was just lucky and the only one that didn't do it. From that lack of reply's we must done be the only ones that don't remove it.
Old Apr 28, 2008 | 05:24 PM
Rick 547's Avatar
Rick 547
I've removed the maxi fuse before installation of the advancedsecurity system. The ony reason I did was because I had to remove the computer to install the security module.
Old Apr 28, 2008 | 07:54 PM
OD_Cleaver's Avatar
OD_Cleaver
It only becomes an issue when you or your tools short out an object of higher potential to an objectof lower potential. You know, like a part with 12 volts on it to ground. If you are lucky, one of those little fuses will blow before any damage happens. If you are real lucky, you will have a spare.
So, good luck.
OD
Old Apr 30, 2008 | 09:41 AM
bucs012's Avatar
bucs012
ORIGINAL: OD_Cleaver
So, good luck.
OD
Good to know. As long as you're working on your bike at home, we should be just fine. On the road I would remove the Maxi Fuse for sure.
Old Apr 30, 2008 | 11:11 AM
IBHarley's Avatar
IBHarley
I like it when they tell you to remove the positive battery cable and the Maxi fuse
Old Apr 30, 2008 | 01:36 PM
MyFirstHD's Avatar
MyFirstHD
Not to highjack the thread, but does anyone carry a spare maxi fuse?
Old Apr 30, 2008 | 01:43 PM
DZLDR's Avatar
DZLDR
I carry a few spare fuses, my old stock shift linkage, a CO2 tire cartridge repair kit. I have never needed them my self, but have made several friends for life by doing so. I can't believe I actualy got my old shift linkage mailed back to me from someone I gave it to that was on the side of the road wiring his broken one back on.
ORIGINAL: MyFirstHD
Old Apr 30, 2008 | 01:48 PM
MyFirstHD's Avatar
MyFirstHD
I heard that carrying spare parts is insurance against needing them.
