Maxi Fuse Removal?
Old May 3, 2009 | 08:37 PM
biker777's Avatar
biker777
Stage II
Default We have a maxi Fuse???
where is it even located? is it marked "maxi fuse"? remove before maint..etc??
Old May 3, 2009 | 08:44 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Word of advice, if you have the factory security system, turn your ignition switch on, then pull the maxi-fuse.
If you turn the switch off to do other work, turn it back on before you plug the maxi fuse back in.
If not, I've found that the siren (if so equipped) will go off and will not shut off until you cycle the ignition switch.
HDV-GLIDE's Avatar
HDV-GLIDE
Big Orange colored fuse to the right of the fuse block.....can't miss it...
Old May 3, 2009 | 09:17 PM
Gtsdesigns's Avatar
Gtsdesigns
good advise...
here is the thing for me... it takes 1 second to remove it and put it back in, so why not just remove it..., depending on what you are doing, the half a second it takes, may be worth the money...
Old May 3, 2009 | 09:59 PM
captjon37's Avatar
captjon37
Takes 1 second to remove it and less than that to fork up a lot of $hit by not doing so. If you are lucky you will blow the fuse when you touch the right tool to the wrong thing but i have seen some sweet wire damage on 2 bikes that required a new harness because the owners thought that they were that good at what they do and they don't need to follow the book. Keep doing what your doing, the dealers depend on it and thank you for being you.
Old May 4, 2009 | 01:46 AM
Punkin's Avatar
Punkin
I've done lots of electrical work over the years and have collected some nice tools with welded spots, missing pieces, pitts etc. I find that I don't enjoy the electro=shock therapy nearly as much as I used to. Mebbe 20 seconds to pull the fuse vs many potential hours of repairs. Mobile arc welders unite!
Old May 4, 2009 | 07:38 PM
Primo's Avatar
Primo
My 2 cents: It's way too easy to pull and replug the Maxi-Fuse that it would be ridiculous not to.
10 seconds of time vs. potential for damage.
No brainer in my book.
Disclaimer: Just my opinion. Results may vary. Do not operate heavy machinery or......
Nonskid
Milwaukee Eight (M8)
16
Apr 12, 2017 02:51 PM
JuanderBoy
Mar 20, 2017 02:12 PM
jcarruth
Mar 17, 2017 02:32 PM
EGlideKid
Feb 9, 2014 11:51 PM
Jul 23, 2009 02:07 PM
