? for all you audio guru's
Old May 1, 2008 | 03:43 PM
Bannana Boat's Avatar
Bannana Boat
Default ? for all you audio guru's
I am wanting to change out the stock speakers on my new 08 FLHX that is due in next week to a set of Kicker KS5250's. They are rated at 4 ohm impedance. Idid a search and found that someone had commented that they may cut out. I called my local radio installer and he says he hassold lots of 4 ohm speakers for HD's and never had one come back with problems. He said a 4 ohm speaker will just have less volume with the same amount of power running with a 2 ohm deck. Any opinions or issues some of you have had with 4 ohm speakers?
Thanks, Scott
Old May 1, 2008 | 03:52 PM
midget11's Avatar
midget11
Default RE: ? for all you audio guru's
Lots of info on this subject can be found using the seach function......
Old May 1, 2008 | 04:45 PM
hdxbones's Avatar
hdxbones
His post said he did a search....
Old May 1, 2008 | 06:26 PM
Bannana Boat
Anyone? Bueller? Frye?
Old May 2, 2008 | 03:04 AM
a911scanner's Avatar
a911scanner
ORIGINAL: Bannana Boat
I Idid a search and found that someone had commented that they may cut out. I called my local radio installer and he says he hassold lots of 4 ohm speakers for HD's and never had one come back with problems. He said a 4 ohm speaker will just have less volume with the same amount of power running with a 2 ohm deck. Any opinions or issues some of you have had with 4 ohm speakers?
Thanks, Scott
Scott,
What I've seen on this forum most of the time is thoughts from people who have not necessarily been in the business, rather they have done stuff on their own through the years or gotten advice from their local installer (like you did) or guys like Pez from Hogtunes. While this can be an excellent way to get info or formulate an opinion, a pink refrigerator can become a purple elephant very quickly. But I digress...
After being in the stereo install business for nearly 15 years, I can tell you that what your local installer told you is spot on. One thing they failed to mention... you may need to turn up the volume so loud that you will be getting distortion much faster, thereby causing your speakers to possibly fail faster. That doesn't count the need for higher volumes at 70 mph either.
If you are going to go the "better than stock" speaker route, no mater what the nominal impedance of the speaker is you should really get an amplifier as well.
MM
Old May 2, 2008 | 05:29 AM
rickxx's Avatar
rickxx
ORIGINAL: a911scanner
Thanks, Scott
Scott,
MM
yeah, what he said......and 2 ohm speakers.
now, tell me about that purple elephant
Old May 2, 2008 | 05:33 AM
pscheval's Avatar
pscheval
why not put a fw 12" in too! then some 24" rims.... pimp that ride!
I'm stock, I got the upgraded radio and speakers, this was never a issue with me!
Old May 2, 2008 | 12:07 PM
a911scanner
ORIGINAL: pscheval
Are you bone stocck on everything.... or did you upgrade something else that was important to you?
MM
Old May 2, 2008 | 03:15 PM
Bannana Boat
MM,
Thanks for the advice. Is a40-60W rangeamp enough?
Old May 2, 2008 | 04:22 PM
a911scanner
MM,
It would be fine, but you could always do more. When it comes to our bikes, these are the things I considered when approaching my project.
1. Size of product - If it doesn't fit, I can't do it.
2. Quality of product - It might say it does 150 watts, but at what distortion level?
3. Price
4. Amount of power/power handling
Speakers are very subjective, so your ears are the best guide. 5 1/4" speaker will never really handle that much bass, except for a few brands of seperates. When considering those, you also have to consider the size of the crossover & where you can fit them. This is why I don't have the Infinty Perfect 5 1/4 mid-bass & tweeter set-up.
Getting a small enough to fit in the fairing, good quality amplifier is really the trick. You need to have something that will fit into the fairing. Two products that I would consider are Arc Audio & Blaupunkt, based on the size & quality. Stay away from the Pyle products. I purchased the Blau based on the price, very happy...if only I could fit the x-overs from the Perfects...
Plug & play products are nice (read easy)(HogTunes, Hawg Wired, etc) but I just can't believe that for the retail price and the actual size of the amplifier that they can be that high of a quality product (JMEO based on years of experience). That explanation could be a long post, but I really don't intended to disparage a site sponsor or the many people that are very happy with the product, which I'm quite sure work well.
MM
OldPhat
2014-2024 Touring Models
Nov 5, 2017 11:45 AM
RSDUDA
Jun 13, 2010 10:00 AM
jm1211
Jan 5, 2009 09:20 PM
07flicks
Aug 20, 2008 08:20 AM
firemen59
Mar 13, 2008 09:49 PM
