Wiring Question
Old May 4, 2008 | 01:03 PM
CiSmAXz's Avatar
CiSmAXz
Default Wiring Question
I am getting ready to wire up my satellite radio mount and also a powered antenna for the regular radio on my SG. I was going to splice into the cig lighter power from inside the fairing. Is it ok to run both of those from that power or is it too much? Would I still be able to use the lighter for plugging in a GPS later down the road?
Old May 4, 2008 | 01:13 PM
Tinkermc's Avatar
Tinkermc
Default RE: Wiring Question
you need to know currant draw and amp draw
Old May 4, 2008 | 01:35 PM
CiSmAXz's Avatar
CiSmAXz
The satellite mount is the Sirius SIR-PMK1 and requires 12v DC it comes with its own fuse holder which has a 2 amp fuse in it.
The antenna I can't find anything on.
This is what the Magellan website says about the GPS:
POWER Source Li-ion rechargeable 1200 MA, 12-24 V vehicle adapter
Does this help?
Old May 5, 2008 | 08:39 AM
TexasRedneck's Avatar
TexasRedneck
The amperage draw of either of those don't come close to the amp draw of the lighter, so you should be just fine. Now, ah'm not sure of the location of the lighter on the SG - on the UC, you can't plug anything into it because of clearance issues w/the tank when ya crank the bars left. But from an electrical standpoint, ya should be jest fine. You can get a "splitter" from Radio Shack that'll slide onto the male spade connector on the back side of the lighter an' give ya two male slide connection points.....
[IMG]local://upfiles/19857/851742471CC442CA8BE51D9F74B5B179.jpg[/IMG]
Indy Road Dog
May 24, 2012 08:26 AM
mwriggs
Dec 22, 2009 06:30 PM
mrjharley
Apr 17, 2009 10:25 PM
bowler11
Jan 30, 2009 08:15 PM
chiabate
Jun 2, 2008 11:53 AM
