Cruise Control
Old May 4, 2008 | 02:33 PM
Jonpaul's Avatar
Jonpaul
Default Cruise Control
The cruise control on my 2003 Road King Classic (fuel injected) is not operating. The left grip cruise on/off switch shows a red light when activated (as it should). The right grip set/resume switch does not show a green light when activated; I had a new set/resume switch installed and still no green light when set. The brake lights work. When I do a "cable lash initilazation routine (as advised by the HD service manual),the right grip green cruise engage light comes on (as it should) and the RPM does increase (as it should). But, the set switch light (green light) will not activate when engaged on the road, and the cruise controlwill not work. Please help.
Old May 4, 2008 | 03:07 PM
Cheese Head's Avatar
Cheese Head
Default RE: Cruise Control
I had a similar problem on an '05 Road King Classic. The problem was the module at the end of the cable. The module was constantly sending a message to the cruise control that the throttle was turned forward. Once in a while Icould get the cruise to work byslowing down a little bit, roll on the throttle and hit the set button when I got to speed still rolling on the throttle. The trick was that I literally had to be turning the throttle to accelerate when I hit the set button. Dealer didn't have the black cable with the module. All they had in stock was the braided cable.Worked for me. I wanted to put braided cables on anyway and this was the perfect excuse to get the wife's "permission".
Old May 5, 2008 | 04:12 PM
Jonpaul's Avatar
Jonpaul
Thanks for the info. Question: When you say "module" do you mean the module unit under the left side panel?
Rickv8z
Sep 11, 2012 03:11 PM
Oil City Outlaw
Jul 4, 2011 09:26 PM
bsam450
Jul 27, 2010 04:05 PM
VONSCARECROW
May 16, 2007 04:47 PM
jwhull
Jul 28, 2005 11:27 AM
