Starter Problems - Need help
Old May 7, 2008 | 04:17 PM
hoodlum's Avatar
hoodlum
Default Starter Problems - Need help
here's the scenario - the bike is an '05 flht 95", 37G cams about 9.7(ish), stock ignition, starter and battery. the motor was turning over slower and slower. i thought it was the battery and i put it on my trickle charger and it charged up in about half an hour. then last night at work i went to leave and hit the starter button and all i hear is a buzz. i can hear the starter jackshaft kicking out i think, but then it just kind of buzzes or whirrs and doesn't engage the engine at all. i had the batter tested at autozone and it tested good (under a 300 cca load). [/align][/align]i really hate electrical crap, so i would appreciate any help pointing me in the right direction here.[/align][/align]tia[/align]jason [/align]
Old May 7, 2008 | 04:30 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: Starter Problems - Need help
Check for a loose wire - either on the starter or ground - at the frame, starter or battery....good idea ta pull 'em an' brush 'em so they're good an' clean, too.
Old May 7, 2008 | 04:37 PM
Jinks's Avatar
Jinks
If the starter is spinnin' but not engagin' the starter clutch is gone. A major PITA, but it's a "feature" not a "problem". 'Course you could be lucky & I could be wrong...........
DynaRobert82
Dec 2, 2013 05:17 PM
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
madcritter
15
Apr 14, 2008 03:14 PM
Meathooks
Feb 29, 2008 07:14 PM
EasyJoe
Aug 22, 2007 11:06 PM
